kill switch idea......
Its basically a way to incorporate a combination into your kill switch just in case it may be found. basically, my idea involves wiring up 3-5 switches in series.
3 terminal 2 position switches. so either the switch is conecting your wire to ground, or its reconecting it to the circtuit. With anywhere from 3-5 of these wired in series youd have to have all of them in the correct position, otherwise the wire is grounded. PLace a higher amperage fuse in the fuse box, and put a smaller amperage fuse inline with these switches in a secret location UPSTREAM of the switches. If the combination was incorect the fuse would instantly blow.
My idea involves placing all swithces into one location, preferably a hermeticaly sealed sheetmetal box. Also the wire in and out would have to be protected somehow, i was thinking with a braided stainless steel fluid line, and conecting that somehow to the switch box, or a CRES or an aluminum alloy fluid line, like a brake line. Thread a fiting into the switch box, and then the fluid line into that, making it that much harder to tear it apart and manualy hotwire the wire in question. And in the timeconsuming event that this might even be acomplished, the thief first having to find the switch box, hed still have to find the blown fuse which would not be in the fuse box but in some other secret location.
Basicaly youd have to memorize your switch combo (1 up, 2 up, 3 down, 4 up), and upon leaving your car just change their position.
Make a kill switch with a remote control. Place it somewhere inaccessible so it's hard to reach without removing a bunch of things.
For a remote control, you can use a wireless door bell.
Modified by clutcher at 12:10 AM 4/16/2005
