D15B Engine (I've Searched)
Old Apr 15, 2005 | 09:46 PM
Skinflute22's Avatar
Default D15B Engine (I've Searched)
Hello,
i'm new here but i do know how to use the search and i did but didn't come up with what i was lookin for. I'm thinkin about swappin a D15B Vtec in my 91 CRX DX. I would like to know what i would have to have to complete the swap and what i would need to enable the vtec. also could someone give me a rough cost of everything.
thanx
Bryan
Old Apr 15, 2005 | 09:59 PM
d15bcoupe's Avatar
Default Re: D15B Engine (Skinflute22)
mine came pre swapped so i dont know anything about that part, but wiring the vtech is real easy, 3 wires as long as u have the correct ecu
Old Apr 15, 2005 | 10:07 PM
Magick211's Avatar
Default Re: D15B Engine (d15bcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15bcoupe &raquo;</TD></TR><TR><TD CLASS="quote">mine came pre swapped so i dont know anything about that part, but wiring the vtech is real easy, 3 wires as long as u have the correct ecu</TD></TR></TABLE>
Vtec not Vtech
Old Apr 16, 2005 | 04:26 AM
blo2k1's Avatar
Default Re: D15B Engine (Magick211)
guess you didnt search good enough next time push the archived button !
you need(should) convert from dpfi to mpfi good write ups on here search for them
go obd1 or ill be mad (p28 or p08 will do fine)
0bd0 to obd1 conversion harness
and take the bracket that holds the motor mount on OFF the jdmd15b under the timing belt cover and swap the one from the dx engine onto it then put all the mounts on the jdmd15b then drop her in and pray it starts if it doesnt you most likely screwed up your dpfi to mpfi conversion
(if for some reason you cant find what you need to know under the search button then pm me and ill walk you through it)
THE-ACE-OF-SPADES
Aug 22, 2008 05:51 PM
JDMMIKE0505
19
Dec 22, 2007 05:27 PM
xxghettothixxx
Jun 29, 2007 09:42 PM
northkai3
Jun 26, 2005 01:35 PM
91projecthatch
Dec 15, 2002 06:02 PM
