2004 civic maintaince light is on..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 »</TD></TR><TR><TD CLASS="quote">Where is the button to reset this thing?
thanks.</TD></TR></TABLE>
If its a check engine light there is no button, unplug the battery for like 20 min, if that doesnt work, unplug the ecu also for like 20... that should do the trick
but if its matinece it should be on the cluster, u gotta use ur key to push it in
if its the matenence required light at the top of the cluster, put the key in the ignition hold the trip reset button, and turn the key to on, and hold the button till the light flashes and co out, thats just the matenece light that comes every 15k or so when you need a service, i have to reset my sisters for her all the time, always calls me in a panic when it comes on. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi »</TD></TR><TR><TD CLASS="quote">if its the matenence required light at the top of the cluster, put the key in the ignition hold the trip reset button, and turn the key to on, and hold the button till the light flashes and co out, thats just the matenece light that comes every 15k or so when you need a service, i have to reset my sisters for her all the time, always calls me in a panic when it comes on. lol</TD></TR></TABLE>
It's just a light, which popped up at 14K.
Thanks for the info.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmbmalaka »</TD></TR><TR><TD CLASS="quote">if its an '04 then wouldnt it still be under warranty? take that ish to the dealer</TD></TR></TABLE>
Yes the car is under warranty. Why waiste time and gas to drive to the dealorship when i can do it at home. Plus they sometimes don't do it, and make you spend un-necassary $$ at unwanted services.
Bump that, dealerships suck
</TD></TR></TABLE>Bump that, dealerships suck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iROCKtheSOHC »</TD></TR><TR><TD CLASS="quote">read the back of the owners manual it'll tell you how to reset the matenence light</TD></TR></TABLE>
Yup RTFM (Read The ******* Manual)
this happens to the CR-Vs at my work everytime around oil change time... it should say it in the manual... you put the ignition on the on position (don't turn on the car) hold the button that changes you milege for about 10 sec. then it turns off... check your manual just incase its different...
MBDiagMan
15
Dec 24, 2003 06:13 AM
Chaze*R
Jun 2, 2002 11:50 AM
