How much longer are extended studs than stock studs?
Old Apr 15, 2005 | 07:36 PM
Jonathan_ED3's Avatar
Default How much longer are extended studs than stock studs?
Do they come only in a certain length? No place I've looked has the dimensions listed.
I'm looking for something ~1/8th" longer than the factory studs; I don't want to have to use an open ended nut!
Where did you purchase yours?
Old Apr 16, 2005 | 08:51 PM
kess's Avatar
Default Re: How much longer are extended studs than stock studs? (Jonathan_ED3)
What are you doing? Usually longer studs are needed to compensate for wheel shims or racing wheel offsets. If you are going to the trouble of installing longer studs pop for the cost of open ended lug nuts.
Old Apr 16, 2005 | 10:05 PM
DocSean's Avatar
summit racing sells ARP studs...not sure on the length though, you'll have to check.
Old Apr 17, 2005 | 02:26 AM
Wraith's Avatar
kinda o/t , but do you have to spot weld the back of the studs when you install them?
Old Apr 17, 2005 | 12:56 PM
Keith P's Avatar
Default Re: How much longer are extended studs than stock studs? (Wraith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wraith &raquo;</TD></TR><TR><TD CLASS="quote">kinda o/t , but do you have to spot weld the back of the studs when you install them?</TD></TR></TABLE>
No..
Mine I think are 3", and you need to use open lug nuts
JSA
Honda Civic (2006 - 2015)
Apr 7, 2011 02:05 AM
timmy0tool
10
Dec 19, 2007 03:25 PM
dc24me
Dec 7, 2007 11:21 PM
Vp Special K
Nov 22, 2004 05:39 PM
