JDM ITR Header... with a stock ITR cat?
Old Apr 15, 2005 | 07:33 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default JDM ITR Header... with a stock ITR cat?
Ok I have a question that has possibly been asked before? But im sick of sifting through the hundreds of pages that come up searching for ITR CAT and HEADER and various variations. Anyways, I have a B18C5 in my 95 Ej. I also have a JDM ITR header which isnt installed. I have a stock DX cat (lol) on a Apex WS exhaust. Now rather than go with a carsound or other high-flow cat, I was wondering if any of you knew if a stock ITR cat would bolt up to the WS exhaust.. obviously i would weld on a new 2.5 in flange to it, but otherwise, would the length work? Would i be able to trim enough of the end off when changing the flange so it bolts up? Im trying to keep it so i at least have a CHANCE of passing emissions lol.. THX
Old Apr 15, 2005 | 10:58 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: JDM ITR Header... with a stock ITR cat? (JDM_Ej)
Old Apr 16, 2005 | 06:08 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Ok I have a question that has possibly been asked before? But im sick of sifting through the hundreds of pages that come up searching for ITR CAT and HEADER and various variations. Anyways, I have a B18C5 in my 95 Ej. I also have a JDM ITR header which isnt installed. I have a stock DX cat (lol) on a Apex WS exhaust. Now rather than go with a carsound or other high-flow cat, I was wondering if any of you knew if a stock ITR cat would bolt up to the WS exhaust.. obviously i would weld on a new 2.5 in flange to it, but otherwise, would the length work? Would i be able to trim enough of the end off when changing the flange so it bolts up? Im trying to keep it so i at least have a CHANCE of passing emissions lol.. THX</TD></TR></TABLE>
Depending upon which high-flow cat you select, you shouldn't have a problem passing emissions testing. That being said, the ITR cat is approximately 17.5" long, flange-to-flange. All you need is a measuring tape and you should be able to determine how much length adjustment, if any, is necessary. I believe the Civic cat is roughly the same length as that of the Integra, but I can only positively confirm this fact with regard to a Civic Si cat, not a 5th gen. DX.
Old Apr 16, 2005 | 09:07 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: JDM ITR Header... with a stock ITR cat? (Padawan)
Thanks. Thats what I thought. Can you recommend a descent cat? I haven't hurt much good about carsound, as far as functioning as an actual cat.
Old Apr 16, 2005 | 10:55 AM
Padawan's Avatar
Darth ModerVader
Contact Dave at SMSP. He has a number of different options, among them being CARB-legal Car Sound's.
Old Apr 16, 2005 | 11:00 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Already done. Thanks man. Does he have a name on here?
Old Apr 16, 2005 | 11:09 AM
Padawan's Avatar
Darth ModerVader
His Honda-Tech user name is SMSP.
jeremy_dane
Feb 20, 2009 09:07 AM
kchungb17a
Jun 19, 2007 01:35 PM
Kusai.Nihonjin.Desu
Feb 24, 2006 07:01 PM
01arr
Aug 12, 2005 10:36 PM
1329itr00
Jan 11, 2005 08:04 AM
