gsr wont go into any gear
Old Apr 15, 2005 | 07:08 PM
Easyslider01's Avatar
Default gsr wont go into any gear
I have a jdm gsr swap in a eg hatch, not that it matters. Anyways, Im driving along and i felt my clutch getting more and more sensetive throughout the day and just thought it was nothing or it was my imagination. Then it got progessively worse to the point where it wouldnt go into anygear. I looked under the car and theres no tranny fluid leaking or even wet. When i press the clutch its like putting youre foot into a bucket of water and it dosent even return to original position. I managed to make it home 60 miles with using 5th gear alone, it was a miracle. Anyway, my friend says it might be the slave cylinder went. I have no idea. If anyone knows what it is, can they post how to fix it or a thread that shows.
Old Apr 16, 2005 | 04:32 PM
EJtypeR's Avatar
Default Re: gsr wont go into any gear (Easyslider01)
i had a problem where my car wouldnt go into gear when it was running. so i decided to put a new clutch in it and i pulled my old clutch out, the springs on the disc where in a million peices. i dont know if that helped you out any. but if it were me i would pull your tranny off and see what your clutch looks like.
Old Apr 16, 2005 | 04:39 PM
Default Re: gsr wont go into any gear (EJtypeR)
the clutch is fine, it was a very gradual process. Its the master cylinder.
gsr_b20b
Jul 17, 2009 03:53 AM
KekahaB18
May 15, 2005 09:17 PM
Easyslider01
Apr 15, 2005 08:07 PM
tilt
Oct 7, 2002 01:22 PM
NickGSR
Sep 15, 2002 05:26 PM
