relocating fuse box,map sensor,etc..searched but?
i know this has been covered but i can't find a how-to on this i've searched only to find a little info,tried relocating engine bay wires,hiding wires,engine bay,i seen tireneck's car and found alittle info but not much i need help BAD my car is all riped apart,can anyone give me an idea on what to type in search
thanks in advance
thanks in advance
search: engine bay (archives)
https://honda-tech.com/zerothread?id=1161033
all the wires reach inside, you might just need to take off some of the tape on the harness because some wires have more slack inside that tape. The only wires you need to extend is the harness going to the headlights, the battery wire going to the fuse box and the power wire going out from the fuse box to the starter. My resister box is near my clutch pedal and im too sleepy to keep typing more, check the pics.
kreatekustomz
Welding / Fabrication
11
Aug 3, 2009 08:36 AM
