Help! Door Handle Broke! =( Ahhhhhh!!!
Old Apr 15, 2005 | 06:40 PM
jackarse's Avatar
I'm a Jackass
Default Help! Door Handle Broke! =( Ahhhhhh!!!
that part broke and so i cant open/close the door from the inside anymore.. i think theres a cable in there that snapped or something, but is this a common problem among eg owners? how can i fix it?? do i rip that part off? help!
Old Apr 15, 2005 | 06:44 PM
jackarse's Avatar
I'm a Jackass
Default Re: Help! Door Handle Broke! =( Ahhhhhh!!! (Yuck Fou)
bump for some honda tech help!
Old Apr 15, 2005 | 06:47 PM
TeamNextGenChris's Avatar
you need to remove the door panel so you can get to the assembly.either the rod came off the handle assembly,or you broke the lever.you can get the handle off Ebay for cheap,or reconnect the rod if that's the problem.
to remove the door panel you need to remove the handle trim ring(one screw),door cup(one screw),window crank(clip on backside)and plastic screw below the mirror.then pull straight out on the bottom of the panel to release the clips that hold it on,then pull the whole panel straight up to remove it.
Chris
Old Apr 15, 2005 | 06:51 PM
stripes777's Avatar
both of mine broke, and im happy it did. i have auto door locks that are connected to the alarm.
i say im happy they broke because if u have your window slightly down, and some guys uses old school way of getting into your car, they wont be able to get in, since theyll try to use a hanger and pull the lock loose. since its broken, it wont work!
but to answer, your question, im pretty sure its the plastic thing connecting to the rod that broke. it happens when someone is holding on to the door lever open and tries to unlock that clip AT THE SAME TIME.
unless its the rod that jus came loose, u will have to buy a new plastic thing. good luck! if you have an alarm with auto door locks installed, i might suggest leaving it broken on purpose!
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Take off the door panel and look. Its not hard. Three screws and a bunch of pops. Looks like one of thise screws is already gone lol. the other two are in the door handle and a plastic pop screw in the upper right of the door. Now look for the rods. It looks like it just popped off the back of the handle your holding with your finger there... Might just pop back in, if not, new inside door handle. Actually on a second look, your pulling it out???? Theres a screw BEHIND the handle there... unscrew it and that whole thing your bending the **** out of comes off.
Old Apr 15, 2005 | 06:56 PM
jackarse's Avatar
I'm a Jackass
Default Re: Help! Door Handle Broke! =( Ahhhhhh!!! (JDM_Ej)
cool.. so i guess i do have to take off the whole door to get to the problem.. arg!
anyway, thanks for all the fast responses! and thanks for helping!!! i love you guys..
Old Apr 15, 2005 | 07:27 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yuck Fou &raquo;</TD></TR><TR><TD CLASS="quote">cool.. so i guess i do have to take off the whole door </TD></TR></TABLE>
NO. Only remove the door panel and everything is visible enough to from there. Two rods just hanging there, I replaced my brothers about two weeks ago.
Old Apr 15, 2005 | 07:38 PM
biela's Avatar
Default Re: Help! Door Handle Broke! =( Ahhhhhh!!! (INVALID)
did anyone glued that piece?? the lock piece? i need to do it. wich glue product should i use?
Old Apr 15, 2005 | 08:05 PM
BoostfedEK4's Avatar
i dont think you should use glue for that.
Old Apr 15, 2005 | 08:11 PM
INVALID's Avatar
Default Re: Help! Door Handle Broke! =( Ahhhhhh!!! (biela)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biela &raquo;</TD></TR><TR><TD CLASS="quote">did anyone glued that piece?? the lock piece? i need to do it. wich glue product should i use?</TD></TR></TABLE>
You're asking for a repeat problem, especially gluing a piece that requires motion to function.
Old Apr 16, 2005 | 10:22 AM
jackarse's Avatar
I'm a Jackass
well i found out that the problem was the plastic piece that connects to the rod broke and so the rod is just hanging there.. blah.. i dont know how to fix that plastic piece so i may just leave it.. anybody know anyone selling power windows?
Old Apr 16, 2005 | 05:32 PM
INVALID's Avatar
Switching over to power windows isn't going to resolve the issue with the lock. Removing the piece is a lot easier than what you're thinking, if anything just replace the entire metal piece that holds on both the handle and the lock/unlock switch. I picked one up at that junkyard for like $10 if even that.
Old Apr 16, 2005 | 07:30 PM
biela's Avatar
i wish i could find this here but.. finding parts its a lot dificult ill need to repair the plastic somehow
Old Apr 16, 2005 | 08:57 PM
suspendedHatch's Avatar
If it's just that little clip that holds the rod to the mechanism, you could probably make something work or easily find it at the junkyard. I'll bet nearly all 80's - 90's Hondas use it. BTW, just take out that one screw holding the plastic cover over the door handle. No need to remove the whole interior door trim.
stripes777: they can still easily get into your car with a coat hanger or they can even pick your lock. There's a rod connecting your door key cylinder to the latch, pop that off and then cut off the little loop that its connected to at the latch. Then you'll be as safe as you think you are now.
Old Apr 16, 2005 | 11:21 PM
INVALID's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biela &raquo;</TD></TR><TR><TD CLASS="quote">i wish i could find this here but.. finding parts its a lot dificult ill need to repair the plastic somehow</TD></TR></TABLE>
Why don't you just search the classifieds here in search of the parts you need?
Old Apr 17, 2005 | 05:54 AM
biela's Avatar
80´s honda use this part?? the same??
Old Apr 17, 2005 | 06:24 AM
biela's Avatar
i need this part. and its plastic bolt
Old Apr 17, 2005 | 08:47 AM
RACEPAK's Avatar
I glued mine with epoxi... it lasted about 2 months and than braked again. than i glued it again and this time it lasted 1 month....
now its broken....
i got one like this from a junkyard off a 96 coup and it was a bit smaller than the one i have (i have a 97 hatch).....
Old Apr 17, 2005 | 10:04 AM
DBLAZE's Avatar
YOOOO Invalid: That is a hot *** pic u have next to your name...Its from that movie where the dude isn't supposed to be in the space program so he steals the other dudes identity to get there....HOTNESS!!!
Oh yeah....sorry bout your door handle and lock dude....just don't use any glue and go to the dealership and buy your parts....
Old Apr 17, 2005 | 09:47 PM
INVALID's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biela &raquo;</TD></TR><TR><TD CLASS="quote">i need this part. and its plastic bolt
If I actually go out and spend the $5 or 10 to get this part for you, are you going to want it or leave me holding it, looking at it everyday on top of my desk?
<FONT COLOR="grey">Good eye Dblaze </FONT>
Old Apr 18, 2005 | 04:39 AM
biela's Avatar
i see i dont understand. if u check my location.. i cant go out and buy..
yes i could go to the dealership directlly from honda...
but.. would anybody in this forum pay 350 bucks for that piece of ****?
i dont think so. in not flying untill next year.. i know there, its worthless .. so im looking foe someone willing to ship the part. i know shipping cost more than the part, but i have no choice..
Modified by biela at 6:46 AM 4/18/2005
Old Apr 18, 2005 | 05:38 AM
RACEPAK's Avatar
just leave it like this.....
Old Apr 18, 2005 | 07:40 AM
pr_tony_montana's Avatar
Default Re: Help! Door Handle Broke! =( Ahhhhhh!!! (RACEPAK)
i need one of those locks too if anyone has one for sale lmk.
Old Apr 18, 2005 | 07:45 AM
INVALID's Avatar
You're missing what I am saying. I am asking if when I go to the junkyard next time and pick this item up for YOU, are you going to leave me holding this part?
Old Apr 18, 2005 | 11:19 AM
biela's Avatar
perfect.. PM me..
doughboixx
Jun 27, 2007 08:11 PM
killaj12
11
May 6, 2007 02:38 PM
ckehl13
Jan 7, 2005 08:56 PM
SoCaLNaTIvE
May 11, 2004 07:44 AM
babyviper97
Jan 10, 2003 05:14 AM
