obd-0 obd-1 swap????
Old Apr 15, 2005 | 05:02 PM
Mikey361's Avatar
Default obd-0 obd-1 swap????
okay i searched, didnt find what i needed. im looking to build a turbo b16a for my 90 si, but as you all may know the 1st gen b16's are obd-0, what all parts wise will i need to swap over to obd-1, ecu, dizzy, conversion harness, what else??? the reason i ask is because of tuning , im going with hondata s200 with boost option . thanks for any help in advance.
turbo, b16 shooting for 350 to the wheels, daily driven.
Old Apr 15, 2005 | 06:11 PM
91B16HF's Avatar
i'm also interested in this topic
Old Apr 15, 2005 | 06:16 PM
hondaguyef's Avatar
Default Re: (91B16HF)
OBD1 dizzy, obd1 ecu, 4 wire o2 and the conversion harness.
http://www.jkobd.com
Phil
Old Apr 16, 2005 | 08:44 AM
Mikey361's Avatar
Default Re: (hondaguyef)
so it seems pretty straight forward.
Old Apr 16, 2005 | 11:04 AM
hondaguyef's Avatar
Default Re: (mle_92cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mle_92cx &raquo;</TD></TR><TR><TD CLASS="quote">so it seems pretty straight forward.</TD></TR></TABLE>
It's very easy. If you buy the JK obd conversion harness the instructions are step by step and he gives great customer service. (Blown90hatch) Jason Koehler is the owner. PM him and he will hook you up.
Click Here
Phil
Old Apr 16, 2005 | 06:09 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
Click Here
Phil</TD></TR></TABLE>
Werd. OBD1 ecu, distributor and 4 wire O2 sensor(although you can disable it in Hondata so its up to you.) and my OBD0-1 conversion harness. With my harness, detailed instructions will be included for an easy install. Let me know if you need a distributor jumper as well.
Check here also: https://honda-tech.com/zerothread?id=997093
Old Apr 17, 2005 | 07:19 AM
Mikey361's Avatar
Default Re: (Blown90hatcH)
thanks got everything i think i need.
cnowak
Jul 28, 2013 07:48 PM
koleslaw
Mar 24, 2007 09:39 PM
teggytegteg
Apr 16, 2006 12:11 AM
euy
Aug 4, 2004 07:15 PM
quaker
Jan 7, 2004 08:15 PM
