215/45/15s on GSR fat 5s?
Hey guys, I'm going to have to buy some tires hear in a couple weeks and was curious how many if any are running 215s on 15" rims? will they fit on stock GSR rims? Also, it's going on my 94 gsr if that makes a difference. I thought I heard something about spacers needed. is that true?Thanks
Are you lowered at all? If not, it shouldn't be a too big of an issue. But I really wouldn't get anything wider than 205's on stock rims. You'll get a very mushy feel when cornering, because your 6" rims will not compliment the 215's too well. Go with stock 195's or 205's, at most.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannaTypeR »</TD></TR><TR><TD CLASS="quote">the ones i'm looking at are actually 50s </TD></TR></TABLE>
why???....youll end up messing with the gearing of the car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">
why???....youll end up messing with the gearing of the car</TD></TR></TABLE>
well..50 is alright..but 215?
..i think its too wide.
btw: messing with the gearing of the car u mean something will broke or what
..i think its too wide.btw: messing with the gearing of the car u mean something will broke or what
WTF are you talking about? 205/50/15 and 215/50/15 comes the closest to the stock 195/55/15. With 205/55 and 215/55, you'll throw off your speedo even more. And how exactly does the size of tire mess up your gearing?
I've never once heard that before
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut »</TD></TR><TR><TD CLASS="quote">
with the 205's and the 215's it increases the width of the tire and won't mess with the speedo, when you decrease the height of the tire youll mess with the speedo and you'll lose cushioning between the road and the rim
</TD></TR></TABLE>with the 205's and the 215's it increases the width of the tire and won't mess with the speedo, when you decrease the height of the tire youll mess with the speedo and you'll lose cushioning between the road and the rim
with the 205's and the 215's it increases the width of the tire and won't mess with the speedo, when you decrease the height of the tire youll mess with the speedo and you'll lose cushioning between the road and the rim</TD></TR></TABLE>
if i'm not mistaken the height of a 205/50 tire differs from a 215/50 tire.
if i'm not mistaken the height of a 205/50 tire differs from a 215/50 tire.</TD></TR></TABLE>
nope 205 and 215 is the width of the tire 50 and 55 is the side wall height
also when i had my fat 5's i ran the stock size tires to keep the whole diameter of the wheels the same as my 14's
It's not exactly the height; it just helps you calculate the height because it's the aspect ratio. So if a 205/50 and 215/50 Brand X from the same company are put next to each other, the 215mm-wide tire will be taller.
</TD></TR></TABLE>It's not exactly the height; it just helps you calculate the height because it's the aspect ratio. So if a 205/50 and 215/50 Brand X from the same company are put next to each other, the 215mm-wide tire will be taller.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">i just realized i was wrong</TD></TR></TABLE>
You're like the fifth person on Honda-Tech I've ever seen who has admitted to being wrong about something. You have my respect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannaTypeR »</TD></TR><TR><TD CLASS="quote">I've never once heard that before</TD></TR></TABLE>
Changing the tire's diameter changes the effective final drive ratio compared to stock size tires. A larger tire effectively lowers the final drive ratio, making the car accelerate slower. A smaller diameter tire effectively raises it, and makes acceleration a bit quicker.
masterxfob
Sep 27, 2001 01:42 PM
on my da i ran 50's ...sry bout telling you 55's..
