what should i look at first?
Old Apr 15, 2005 | 09:00 AM
Origin's Avatar
Default what should i look at first?
i have a little problem, the problem has persisted on and off for the past month and now i don't have any light from the cluster nor the rear tail lights, i keep blowing/melting the bottom 6th from the right fuse. has anyone else had this problem? or better yet, know where i should start looking? im trying to find a fuse box to replace the one in my car now just to see if that will help. anyone else think that two wires are grounding out eachother, if so do you know the path the wires take from that point. this is getting really aggrivating, so any help would be appreciated.
Old Apr 15, 2005 | 03:18 PM
bagpipe goatee's Avatar
i had a similar problem. leaking water from the windshield onto the wiring harness. I've also heard of fuse boxes going bad.
Old Apr 15, 2005 | 06:47 PM
Origin's Avatar
Default Re: (bagpipe goatee)
yeah i think i might try and take a trip to the junkyard and see about getting another fuse box. thanks for the help.
Old Apr 15, 2005 | 10:26 PM
hahagasdcrx's Avatar
Default Re: (Origin)
might have been that brick in the road you hit!!!!
Gimme a call if you cant get it figured out......
Old Apr 16, 2005 | 12:06 AM
Origin's Avatar
Default Re: (hahagasdcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahagasdcrx &raquo;</TD></TR><TR><TD CLASS="quote">might have been that brick in the road you hit!!!!
Gimme a call if you cant get it figured out...... </TD></TR></TABLE>
haha i wouldn't be suprised if the jolt did jar something lose. thanks man, im gonna try and make it to a junkyard tomorrow before work to get that fuse box. ill let you know if it didn't solve the problem.
Old Apr 16, 2005 | 12:15 AM
Redline130's Avatar
Interesting, my dad's Toyota pick-up just had a similar problem with cluster lights and tail lights not working. Turned out to be a loose wire near the switch. As much as it is a pain, I'd check the wiring from the switch to the fuse box.
Old Apr 16, 2005 | 06:46 PM
Origin's Avatar
Default Re: (Redline130)
really? does anyone have a diagram of what wire is the one i should trace? thanks for the help. i guess i could follow backwards from the light to the switch? that makes sense right? haha
Monstarrr*
Apr 13, 2012 04:55 PM
XRacerX
Sep 9, 2009 08:50 AM
El3ments
Jun 2, 2008 11:55 AM
y2kferari
Mar 28, 2007 04:46 PM
trini-laser
Aug 12, 2005 09:14 AM
