10-40w or 15-50w?
what weight oil should i use. i have 97 civic with 143000 miles. i also have some valve lash, and since i dont unerstand the chilton's instructions, i would like to possibly quiet it down with heavier oil. im going to use red line synthetic...10-40 or 15-50?
well, the guy i went to said itll be between $70-140. i want to do a motor swap at the end of the summer, so i dont know if i want to spend that much, but...10-40 then? thanks
i have the feeler gauges and stuff for the valve adjustment. but i was trying to do it from the chilton book, and i didnt quite get it, and there wasn't really any pictures. if anyone has pics or could try and explain it that would be really awesome. thanks
Just something I found when doing them, a "slight drag" is more like "barely can get the gauge in and out". I did them with a "slight drag" one time and it was horrible.
EDIT: Go ahead and invest in a Helms. It's 62 dollars and will save you a TON in the long run.
mithious
19
Apr 21, 2015 03:23 PM
