Si fuel injectors in my dx rex?
Old Apr 15, 2005 | 08:50 AM
jester's Avatar
Default Si fuel injectors in my dx rex?
I just wanted to see if they are inter-changable-- I know I have 2 and the si/hf four but if they fit I have some I can get from a friend to use instead of paying for new ones
Old Apr 15, 2005 | 08:55 AM
EP3_05's Avatar
Default Re: Si fuel injectors in my dx rex? (jester)
I think the dx injectors are completely different from the Si as far as how they are powered and their flowrate.
Old Apr 15, 2005 | 09:14 AM
FalkenSiR's Avatar
Default Re: Si fuel injectors in my dx rex? (91civic)
and the plugs are diff so they wouldn't even be able to be hooked up.
Old Apr 15, 2005 | 09:31 AM
CRX Toad's Avatar
Default Re: Si fuel injectors in my dx rex? (fast88std)
DX and Si injectors also have different impedence one is low and the other is high. Hence the reason for a resistor box on the Si and HF. Is there something wrong with yours? I may have a couple used DX ones...
Old Apr 15, 2005 | 01:48 PM
jester's Avatar
Default Re: Si fuel injectors in my dx rex? (CRX Toad)
I figured there would be a problem with switching them
My injectors are probably clogged. I have what I call "ghetto vtec" because my engine is kinda stalling and then it hits a certain point and its like the gas is passing through the injectors quicker or something
hard to explain but figured why not just replace them
Old Apr 15, 2005 | 03:39 PM
bagpipe goatee's Avatar
sounds like it could be your tps, too.
Old Apr 18, 2005 | 04:10 PM
jester's Avatar
Default Re: (bagpipe goatee)
I checked the codes that it was throwing..
I am getting a tps sensor and also my fuel injectors.. So I guess its both that needs to be replaced..
I know the fuel injectors are an easy switch but how about the tps sensor?
Old Apr 18, 2005 | 04:57 PM
FalkenSiR's Avatar
Default Re: (jester)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jester &raquo;</TD></TR><TR><TD CLASS="quote"> I have what I call "ghetto vtec"</TD></TR></TABLE>
lol. I tried switching my 2 std injector plugs and it bogged down and wanted to stall. It runs way too rich.
Old Apr 19, 2005 | 05:40 AM
jester's Avatar
Default Re: (fast88std)
hrrm I may not want to even try it then.... Just my luck I will screw something up
journeyquest
Aug 4, 2008 04:34 PM
shadycrx
11
Jan 2, 2006 07:03 PM
baked_beanz
May 25, 2005 01:56 PM
Josho_17
Mar 20, 2003 04:50 PM
