H22a and H23a1 intake manifold difference ???
Old Apr 15, 2005 | 07:19 AM
OzWolfbane's Avatar
Default H22a and H23a1 intake manifold difference ???
Hi.
Is there any difference between H22a and H23a1 intake manifold ??? My H22a was broken so I put a H23a1 from my engine swap...is there any difference between the two ???
thanks
Old Apr 15, 2005 | 12:24 PM
accord387's Avatar
wtf... do you mean TB? because the h23a1 manifold does not bolt up to the h22a head.
Old Apr 15, 2005 | 06:07 PM
OzWolfbane's Avatar
Default Re: (accord387)
One of the mounting screws was broken and ****, and needed to be drilled out and stuff, so he just used my H23 one.... the yellow circle is the part im talking about, might be called soemthing else !!!
This is not my car btw...dirty
Old Apr 15, 2005 | 06:10 PM
optikal_blitz's Avatar
how you got the IM to bolt up is completely beyond me... you sure it was an h22 IM? i think the size of the runner outlets is different? and the bolt holes wouldnt really line up
Old Apr 15, 2005 | 06:54 PM
tarheelsoldier's Avatar
Default Re: (NatakuBlitz)
the top of the intake manifolds between the H23 and H22 are the same. the lower section, below the runners are different. so if he had to replace that section, thats what was replace. (runners section with vac tube) The lower section on H22 IM is for the Vtec and same with H23..... other than that the manifolds can be interchanged.--- this being the section that was circled
Old Apr 16, 2005 | 02:41 PM
accord387's Avatar
plenums are interchangable, but the runner section have different bolt locations. so the runner section will not interchange.
jdm 1080p
Mar 17, 2013 05:20 AM
1SIKZ31
Jan 8, 2007 05:48 AM
92h22a
11
Oct 1, 2003 11:13 PM
