2006 CRX!!!!!!!!!
Old Apr 14, 2005 | 11:59 PM
whiteknightef's Avatar
Default 2006 CRX!!!!!!!!!
anyone have any pics that they want to share that they think the new crx will look like??
Old Apr 15, 2005 | 12:03 AM
ServiceAdvisor's Avatar
Oh man, not another one of these ignorant posts. If the CRX was coming back, we'd of had pics and links by the dozen atleast a year before production. Use the search function and you will find tons of info on what many users here **imagine** the next CRX would look like, if it was to be remade. - Darrell
Old Apr 15, 2005 | 12:09 AM
kim_2_da_chee's Avatar
Default Re: 2006 CRX!!!!!!!!! (trigger69)
Searchie searchy
more searchy
"While Honda thinks about reintroducing one of its most glorious models, we can't help but blurt out our full support, - this is a no-brainer, guys.
The CRX was brilliant when Honda developed it almost 20 years ago, and the tearaway combination of light and potent hasn't lost its appeal. Honda is believed to be seriously considering developing a two-seat sports car with those qualities, using its new Global Small Platform. The car, which Honda insiders are already calling the CRX, could appear in late 2004 or early 2005.
For the Japanese market, the CRX will exist in two forms: an entry-level model with a 1.0-litre DOHC VTEC triple producing appoximately 74 kW (the engine derived from the block used in Honda's Insight hybrid coupé), and a hardcore 1.6-litre DOHC four cylinder engine (also with VTEC) generating 110-115 kW. Not incredible, until you realise that the target weight for the four-cylinder coupé is said to cut under 800 kg. Put it this way - that's 200 kg less than the Mini and 175 kg lighter than an MR2.
This gives the 1.6-litre variant a tidy 7.27 kg/kW ratio in the worst case. By comparison, a 225 kW VXII SS Commodore has a kilogram-to-kilowatt ratio of 7.52. So, if Honda builds it, the little CRX will stand-out quick. Transmissions proposed are a five-speed manual for the 1.0-litre three cylinder, and a six-speed manual for the 1.6-litre. Use of Honda's CVT is said to be under study, but is not yet an official part of the programme.
The new two-seater is small, and information from Honda indicates a wheelbase in the 2250 to 2350 mm range, overall length of less than 3650 mm, width of 1690 mm and height below 1270 mm. This makes it a strictly a two-pew affair.
My answer to the bold print: "Ok, whatevAR"
Modified by kim_2_da_chee at 1:36 AM 4/15/2005
Old Apr 15, 2005 | 12:27 AM
alecjoesph's Avatar
Default Re: 2006 CRX!!!!!!!!! (kim_2_da_chee)
where did you find that
Old Apr 15, 2005 | 01:42 AM
Default Re: (DOHCZCCRXSi)
MAN IT IS TRUE AND YOU CAN'T BE A DICK ITS JUST A QUESTION LAY OFF MY POST.
Old Apr 15, 2005 | 02:11 AM
96-EJ6 B18C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kim_2_da_chee &raquo;</TD></TR><TR><TD CLASS="quote">
I'm feelin' it, just lower that roofline a bit.
Old Apr 15, 2005 | 02:56 AM
limpy's Avatar
Default Re: 2006 CRX!!!!!!!!! (96-EJ6 B18C)
use the damn search button located at the top of your screen... and since i have nothing better to do i searched for you and found this.... it is a photochop but ehh... you get the idea. ohh and by the way honda has not confirmed anything about bringing back the crx.http
://www.honda-tech.com/zerothread?id=1148020 haha... forgot to copy link location just copy/paste into your browser.
Old Apr 15, 2005 | 05:59 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kim_2_da_chee &raquo;</TD></TR><TR><TD CLASS="quote">Searchie searchy
more searchy
Modified by kim_2_da_chee at 1:36 AM 4/15/2005</TD></TR></TABLE>
EdmontonHonda
Apr 24, 2016 09:33 AM
RCSenna
Dec 2, 2015 09:55 AM
komet 163
Jan 18, 2015 07:19 PM
88crxhfb16
25
Jul 4, 2005 11:26 AM
RussHondaCRXVtec
48
Sep 9, 2003 05:00 PM
