Civic/H22 (EG) Suspension setup?!
Hi there!
Could anyone give me some advice what suspension/coilvers i should use for my Honda Civic Hatchback -94 when driving it with an H22 swap.
I want to use the car mainly @ 1/4mile track so there for..i need a drag setup.
What kind of dampers . springs and so on..or if u have anything to sell
Best Regards
Jonas Eriksson
SWEDEN
Best Regards
Jonas Eriksson
SWEDEN
personally I like ground controls + koni yellow's. Just get a good spring rate for launching (they will give you custom spring rates if you ask), and you'll be set.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">personally I like ground controls + koni yellow's. Just get a good spring rate for launching (they will give you custom spring rates if you ask), and you'll be set. </TD></TR></TABLE>
12k springs in the front and 18k in the rear
more can be found here on their website
http://www.omnipowerusa.com
It seems nice..
500$ is for a complete set of 4pcs shocks and springs , right?
http://www.omnipowerusa.com/Pr...s.asp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOFASTR »</TD></TR><TR><TD CLASS="quote">It seems nice..
http://www.omnipowerusa.com/Pr...s.asp</TD></TR></TABLE>
no for the drag combo we sell them for $750
2 sports in the front and the 2 drag rears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebp 99 si »</TD></TR><TR><TD CLASS="quote">
2 sports in the front and the 2 drag rears</TD></TR></TABLE>
Aha..so this setups is ideal for drag , is it a special package ur doing after demand or? , hm...problem is i live in Europe...SWEDEN to be exact..
perfect for drag
a customer/friend's car dropped .4 in the 1/4mile from switching to these from koni/groundcontrol
yeah it's a package we do
i can check w/ the owner and see if we can ship international
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocket_R »</TD></TR><TR><TD CLASS="quote">how many lbs are the non drag setups? what if later on one of the shock blows, to i have to replace the whole thing?? anyonbe driven the drag ssetup on the streets? how does it feel?</TD></TR></TABLE>
Feels like crap, but some people get used to it. You can always swap out the rear for track days, but that's just a hassle, so many people opt to daily drive with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebp 99 si »</TD></TR><TR><TD CLASS="quote">perfect for drag
Something was seriously wrong with his gc/koni's if he dropped .4 in the 1/4 by switching. I wouldn't even expect that big of a change from blown stock shocks/springs to a drag setup. Either that, or he changed more than his suspension between runs.
Something was seriously wrong with his gc/koni's if he dropped .4 in the 1/4 by switching. I wouldn't even expect that big of a change from blown stock shocks/springs to a drag setup. Either that, or he changed more than his suspension between runs.</TD></TR></TABLE>
all he changed was the suspension and added a set of traction bars and went from a 10.79 to a 10.44
suspension plays a major roll in drag racing. what good is power if you cant put it to the ground? my car is putting good power to the ground but i cant get the front end to stay down mid track. a racing buddy of mine puts down the same amount of power but he has his suspension tuned and he runs a way faster time than i do. id say you go with the omnipower suspension, energy suspension bushings and a nice set of traction bars. that should help with putting the power to the ground. hope this helps!
I know its important, but I'm running 13's, not 10's. I really doubt the omnipower's could even save me a tenth over gc/koni's. In a 10 sec car, I can understand, but that's a whole new ballgame.
an employee's car is a 94cx hatch with a jdm itr swap went from 13.3 to 12.8 by putting the omnipower on his car
but he had skunk2 coilovers and kyb shocks on before instead of koni/gc
I find that hard to believe. half a sec on a 13 sec car from spring/shocks? He must have been driving like **** when he ran that 13.3, or diff tires or something.
Either way, I'm not trying to start an argument, but I can only assume that IF that is true, then it will have the opposite effect on handling, and make it that much worse in the turns.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">I find that hard to believe. half a sec on a 13 sec car from spring/shocks? He must have been driving like **** when he ran that 13.3, or diff tires or something.
Either way, I'm not trying to start an argument, but I can only assume that IF that is true, then it will have the opposite effect on handling, and make it that much worse in the turns.</TD></TR></TABLE>
i also found it hard to believe until i saw it happen
i about **** myself
not sure how it is in the turns though
i about **** myself
