Need Help...Swapped JDM D15b and Throwing (3) Codes
Old Apr 14, 2005 | 10:18 PM
NorcalHB94's Avatar
Default Need Help...Swapped JDM D15b and Throwing (3) Codes
ok so everything is in and running fine except for a couple small factors...
i'm throwing codes:
19 - Automatic Transmission Lockup Control I guess this has something to do with why i can't take the car out of park without using the shift lock release.
21 & 22 - VTEC solenoid and pressure switch i'm pretty sure i know the reason for this problem...
Here's the engine bay wiring harness plug showing the Blue/Black wire from the VTEC pressure switch
Now, the other side of the plug for the wiring harness going inside to the ECU
this is a problem...the VTEC wire is basically a dead end....do i need to get a new harness for the ecu to the engine bay or can i run a wire for this? Thanks for any help
Old Apr 14, 2005 | 10:26 PM
ABK's Avatar
ABK
Default Re: Need Help...Swapped JDM D15b and Throwing (3) Codes (NorcalHB94)
19 is prolly because you got an automatic ECU, just chip it to manual if you are using the right type.
vtec thing you need to wire it up. If you got a 92 you can use the harness and just extend it using some of your own wire. If it's 93-up you need to wire it straight from the ECU. Easy ****.
Old Apr 14, 2005 | 10:32 PM
NorcalHB94's Avatar
Default Re: Need Help...Swapped JDM D15b and Throwing (ABK)
it's an automatic ECU with an automatic tranny....the only problem is shifting from park to any other gear...i've been using the shift lock to start the car in neutral...i can shift between any other gears and back into park...but once it's back in park it won't budge.
and also...do you have a link or anything to tell/show me how to add that wire to the ecu? do i cut the blue.black wire from the plug and run it straight into the ecu?
Old Apr 14, 2005 | 10:40 PM
ABK's Avatar
ABK
Default Re: Need Help...Swapped JDM D15b and Throwing (NorcalHB94)
I never hooked up a vtec in 92. I just run a solenoid wire to designated pin on the ECU (you will need add that pin in, search for wiring vtec on h-t I think the pin is A4), and you need to run wire from the vtec pressure switch to the ecu too (need to put in a new pin into d6).
Old Apr 14, 2005 | 10:50 PM
NorcalHB94's Avatar
well i got a new ecu, it's a p08 vtec ecu so the pins should be there right? wouldn't i just need to run the two wires into it?
oh and the car is a '94 orginally DX
Old Apr 14, 2005 | 11:01 PM
ABK's Avatar
ABK
no you need to add pins to your original harness that came with a car, unless it's 92. The harness where it plugs into the ECU.
Old Apr 14, 2005 | 11:32 PM
NorcalHB94's Avatar
ahhh ok gotcha...i'll take a look at it tomorrow then. thanks
Einhander276
Aug 2, 2011 05:47 PM
RiverRat2
Sep 27, 2009 05:02 PM
pliskin679
Jun 8, 2009 08:36 AM
nutball72
Aug 26, 2006 10:54 AM
brockscivic
Oct 26, 2005 05:34 AM
