195-55-15 vs. 195-50-15
Old Apr 14, 2005 | 06:53 PM
Lil Corb's Avatar
Default 195-55-15 vs. 195-50-15
just a quick question on these tire sizes. I see that the 195-50-15 are cheaper than 195-55-15, is there any downside running the 195-50-15 beside car height being lower than before? should I just stick with the 195-55-15?
thanks
Old Apr 14, 2005 | 06:58 PM
civic_tuner's Avatar
Default Re: 195-55-15 vs. 195-50-15 (Lil Corb)
Go with the 195-50-15's. Theres not much difference and It will be easier on the wallet
Old Apr 14, 2005 | 07:02 PM
Lil Corb's Avatar
aight thanks for the quick response
Old Apr 14, 2005 | 09:11 PM
UncleD's Avatar
Default Re: (Lil Corb)
The 195-55 is exactly the same height for your stock tire size, but IMO the 50's look better and you have a much better selection
Old Apr 14, 2005 | 10:36 PM
LSturbointeg's Avatar
more ppl go with the 195/50/15 vs the 55's...
Old Apr 20, 2005 | 07:06 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lil Corb &raquo;</TD></TR><TR><TD CLASS="quote">is there any downside running the 195-50-15 beside car height being lower than before?</TD></TR></TABLE>
Yes. Your speedometer and odometer will both read 3.3 percent higher than actual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lil Corb &raquo;</TD></TR><TR><TD CLASS="quote">should I just stick with the 195-55-15?</TD></TR></TABLE>
Yes.
Old Apr 20, 2005 | 09:19 AM
95greenteg's Avatar
Default Re: (nsxtasy)
if you like comfort more than performance, stick with the 55 series...50's feel harder on the road...
Old Apr 20, 2005 | 01:30 PM
Mike_C's Avatar
Default Re: (95greenteg)
50s - slightly cheaper, slightly lighter, lower price may be lost in gas since your gearing will be thrown off a little bit, more agressive looking, less comfy, less protection when you hit a pothole
55s - the opposite of everything above
Old Apr 20, 2005 | 01:45 PM
Chris@Tires.com's Avatar
Default Re: (Mike C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">50s - slightly cheaper, slightly lighter, lower price may be lost in gas since your gearing will be thrown off a little bit, more agressive looking, less comfy, less protection when you hit a pothole
55s - the opposite of everything above </TD></TR></TABLE>
I like this comparison!
Old Apr 20, 2005 | 02:19 PM
Mike_C's Avatar
Default Re: (Chris@Tires.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris@Tires.com &raquo;</TD></TR><TR><TD CLASS="quote">
I like this comparison! </TD></TR></TABLE>
thanks!
forgot the 50 will have a slight cornering advantage, but a slight acceleration disadvantage
Old Apr 20, 2005 | 03:06 PM
BudgetBalla's Avatar
wouldn't the smaller overall diameter of the 50 series give better acceleration?
Old Apr 20, 2005 | 04:04 PM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote"> but a slight acceleration disadvantage </TD></TR></TABLE>
Actually the smaller tire will accelerate faster there buckwheat
Old Apr 21, 2005 | 06:23 AM
Mike_C's Avatar
true, my bad. i was thinking of sidewall flex, which would be beneficial in acceleration for the 55
Old Apr 21, 2005 | 08:35 AM
deSigi's Avatar
Are you sure that the price would be lower for the 50's? I was always under the impression that tires with a lower aspect ratio would be more expensive.
Old Apr 21, 2005 | 11:02 AM
Mike_C's Avatar
Default Re: (deSigi)
less material = cheaper.
Old Apr 21, 2005 | 11:07 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deSigi &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure that the price would be lower for the 50's? I was always under the impression that tires with a lower aspect ratio would be more expensive.</TD></TR></TABLE>
That's because you are usually choosing between a WIDER tire and a lower aspect ratio vs a narrower tire with a higher aspect ratio (e.g. 205/50-15 vs 195/55-15).
Old Apr 21, 2005 | 07:32 PM
deSigi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">That's because you are usually choosing between a WIDER tire and a lower aspect ratio vs a narrower tire with a higher aspect ratio (e.g. 205/50-15 vs 195/55-15).</TD></TR></TABLE>
Makes sense, thanks for clearing it up.
LSEGHATCH
May 22, 2007 10:30 AM
99fbpem1
Jul 31, 2006 08:08 PM
$amGD3
Jul 5, 2006 02:01 PM
Tad
22
Feb 21, 2004 01:22 AM
BlackB18CTeg
Aug 19, 2003 09:41 PM
