Unbolting the Intake Manifold h23. Its fun ever tried?
Old Apr 14, 2005 | 05:54 PM
luderollin's Avatar
Default Unbolting the Intake Manifold h23. Its fun ever tried?
So has anyone ever tried to unbolt the manifold. there is that one or two nuts on passangerside under the manifold any tips to get at it i have to get a new gasket on. I cant be the only one with this problem. anyone?
Old Apr 14, 2005 | 06:12 PM
2lude4u's Avatar
Default Re: Unbolting the Intake Manifold h23. Its fun ever tried? (luderollin)
Depending on which two you're talking about. One, or both you can get at from underneath (easier with the oil filter and IAB Vac unit out of the way). The two far lower passenger side nuts (there are two in close proximity) can be reached from above using a socket wrench and an extension.
Basically do whatever you need to do to get at them with a socket wrench and the right extensions. The first time is always timely, but after this it will go faster. I can get a manifold off in less than 10 mins these days, and I get to pull it off along with the head this weekend again.
Old Apr 14, 2005 | 07:52 PM
Ziggymidget5's Avatar
Just took mine off and put it back on, definitely remove the oil filter, and try different types of wrenches. Socket, socket w/extension, small box wrenches, etc. until you can get something to work, they aren't torqued real tight, so you should be able to get it with some experimenting.
Old Apr 14, 2005 | 08:09 PM
92LudeSI's Avatar
Yea I took mine off awhile ago, I got all the actual nuts off from above using a box end wrench. And the bottem support underneith was the hardest part.
Old Apr 14, 2005 | 08:14 PM
Hawkze_2.3's Avatar
Yep, all the bolts are easy except the middle bottom 2 under the IM. Go at those from underneath for sure. Also don't forget about draining the coolant a bit (I always forget that and can be heard screaming "****" for miles around).
boostedh23
Jul 6, 2009 06:34 AM
bigsnorlax
Apr 30, 2009 06:00 PM
prelude beast
Mar 28, 2003 05:53 AM
NathanMorris
Mar 16, 2003 03:21 PM
Panic
Jan 24, 2002 06:02 AM
