Turbo D16 Blown HeadGasket?
Old Apr 14, 2005 | 05:06 PM
TurboTagTeam's Avatar
Default Turbo D16 Blown HeadGasket?
Iv Had the Turbo in for about a month now and im having some problems. Mostly its overheating. It will be totally fine untill i get on it. Then the coolent temp will go sky high then immediatly drop back to normal. The coolant overflow is also overflowing. There is no white smoke comming out of my exhaust, and no oil on my valve cover or in the coolant.
Also I am getting what sounds like a very bad missfire. It will only do it under full throttle and only at certain times. Some days it wont do it at all. But I dont get any check engine lights? It does it alot when i first start up the car then goes away after a second or two. I am ready to change the gasket and install ARP headstuds this weekend but I wanted to see what you guys thought first. Thanks!
Setup:
d16y7
stock internals
5psi
12:1 fmu (just until I get it tuned)
57t t3/t4
Also: I need help with wich headgasket to buy
Old Apr 14, 2005 | 05:33 PM
turbo_b16_ex's Avatar
um, try new thermostat. mine used to that when i boosted it up. i go throught thermonstats like gas. and the misfire... yea could be headgasket. check spark plugs. clean them up
dustin's Avatar
Default Re: Turbo D16 Blown HeadGasket? (TurboTagTeam)
What are you using for a fuel pump?
Old Apr 14, 2005 | 06:07 PM
Default Re: Turbo D16 Blown HeadGasket? (dustin)
MSD inline
Old Apr 15, 2005 | 03:24 PM
bump...Help me out
Old Apr 15, 2005 | 03:27 PM
s2kdre's Avatar
you have a crack in your headgasket, too many experiences, once the tank overflowes its a sign of a bad headgasket.
Old Apr 15, 2005 | 04:19 PM
Default Re: Turbo D16 Blown HeadGasket? (jdmhonda)
I just ordered ARP headstuds but im a little confused on wich headgasket to get. Some people are telling me to get an oem one? Im thinking that a multi-layer metal one would hold up better?Anyone with any suggestions?
Old Apr 15, 2005 | 06:09 PM
Tomek's Avatar
oem headgasket will be fine. Same thing happened to me and 4839483 other turbo d series guys
https://honda-tech.com/zerothread?id=909091 here's a long thread about it.
shadowz
Jun 17, 2005 10:47 AM
greekspeed
Sep 26, 2004 06:02 AM
GruvyTune
Jun 22, 2002 06:11 PM
GruvyTune
Jun 22, 2002 04:58 AM
