Rear Disc Brake Conversion Question
Old Apr 14, 2005 | 05:00 PM
Civic94girl's Avatar
Default Rear Disc Brake Conversion Question
I just did the swap on my 94 Civic Coupe and Im haveing trouble getting the Ebrake cables to strech long enough. Is there a trick to get them to fit??
Please help!
-Jenn
Old Apr 14, 2005 | 05:25 PM
pdiggitydogg's Avatar
gotta ask:
Did you route them correctly?
What cables are you using?
Old Apr 14, 2005 | 05:28 PM
EL Vap133's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">
What cables are you using?</TD></TR></TABLE>
Old Apr 14, 2005 | 08:03 PM
I used the cables that came with the set up and I routed them the same way my old ones came out. Do you think I should unbolt the braket closest to the ebrake handle to give it a little more leway?
Old Apr 14, 2005 | 08:20 PM
A.E Motoring's Avatar
Default Re: (Civic94girl)
wat year are they from? cause there is a certain year i believe that the cables are short
Old Apr 14, 2005 | 08:29 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (SPNFEDEJ)
94-01 Teg cables will work. Yes, loosen the ebrake bracket that holds the ends of the cables in place. Get it back as far as possible.
Old Apr 14, 2005 | 08:36 PM
I dont know the exact year but I do know it was a 94-01 teg. Ill mess with the cables a little more tomorrow.
One more question for you guys... I was told by a few people that since my car doesnt have ABS I didnt need to change the proportioning valve. My brakes seem to be working just fine... but will I have trouble later if I dont change it???
Old Apr 14, 2005 | 08:47 PM
BlueIntegraBoy's Avatar
Default Re: Rear Disc Brake Conversion Question (Civic94girl)
Are you sure you didnt get Del Sol brakes? The cables are shorter.
Old Apr 14, 2005 | 09:11 PM
litterbox's Avatar
Default Re: Rear Disc Brake Conversion Question (BlueIntegraBoy)
Or maybe 99-00 Si Brakes?
Old Apr 14, 2005 | 09:42 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic94girl &raquo;</TD></TR><TR><TD CLASS="quote">I dont know the exact year but I do know it was a 94-01 teg. Ill mess with the cables a little more tomorrow.
One more question for you guys... I was told by a few people that since my car doesnt have ABS I didnt need to change the proportioning valve. My brakes seem to be working just fine... but will I have trouble later if I dont change it???</TD></TR></TABLE>
Then they should fit if they're from a 94-01 Teg.
Old Apr 14, 2005 | 09:52 PM
Neighborhood Superstar's Avatar
using your oem PP valve should be fine for now, but i suggest you get that (4040) and the MC/BB from an non abs integra in the future so you can use those brakes to the fullest extent.
Old Apr 15, 2005 | 08:07 AM
Default Re: (=Gameover=)
Well I tried the easiest place first and Autozone doesnt have proportioning valves... do you know where I should look? Wrecking yards are my next guess.
Old Apr 15, 2005 | 08:12 AM
pgpunkguy's Avatar
i don't think you really need the proportioning valve...
but def get the bigger master cylinder.
if you get the 15/16" MC from a civic ex/si you don't have to swap brake booster.
else go for the integra 1" MC and brake booster.
have fun swapping the booster! (it's a huge PITA!)
Old Apr 15, 2005 | 11:15 AM
litterbox's Avatar
Default Re: (pgpunkguy)
Ok, this is what you are GOING to do:
Pm cxSHOE and he'll get you 4040 prop valve. He did for me, and he's an awesome guy. OR you can get one at http://www.importautosalvage.com for around $50 shipped after talking them down. I still did not want to pay that much so I went with cxshoe.
You are going to get a 1inch MC from a 98-01 Integra. When you go to buy one, don't let people jack the price on you saying that there's is a 1inch type R MC. Every MC after 98 was a 1inch. They're all the same. And get the 98-01 Brake Booster. **** 15/16th.
Now, before you go to install the MC, you'll notice that one of the fitting slots is on the other side of the MC compared to your stock MC. No biggie, just slowly bend the hard brake line over to the other side and line it up. The bigger problem is that that slot for the hard brake line is 12mm and your stock brake line fitting is 10mm. It's too small. You'll need to go to the junkyard and find a 12mm hard line fitting. I found mine off a late model Acura Legend. Then you'll need to dremel your stock fitting off, put the new one on, and double flare the line closed. Use this link to learn how to double flare. The flare kit should cost you around $10 at Advance Auto Parts. http://www.joesfalcon.com/gentip2/gentip2.html (courtesty of cxshoe)
Make sure the bolt pattern on your Brake Booster lines up with your MC. Your BB is an absolute BITCH to install like pgpunkguy said. I NEVER want to do another one again. O it sucks, hahaha. You're screwed lol. It's just 4 scews though. FROM HELL!!!
Good luck
Old Apr 15, 2005 | 11:19 AM
litterbox's Avatar
O ya, for my advice to be truly effective, you need Integra front brakes.
Old Apr 15, 2005 | 11:27 AM
cuz_ican's Avatar
Default Re: (litterbox)
you should try to unhook the cables from the brakes, then install them into the bracket for the e-brake handle....or just buy 95 civic cables w/ rear discs...
Old Apr 15, 2005 | 11:30 AM
cuz_ican's Avatar
Default Re: (cuz_ican)
oh yeah and installing the 1" master cylinder and brake booster is fairly w/ the right tools and alot of patience...good luck and ask more questions if you need more help...
i've done the same sawp on my eh, and on an ef and ek....
Old Apr 15, 2005 | 01:36 PM
jolt-tsp's Avatar
The cables may need to be zip tied on a new route instead of using the stock route.
Also, expect your front brakes to lock up before the rear until you change the prop valve (better than rears locking up before fronts, but still something to fix when you can)
Old Apr 15, 2005 | 01:56 PM
Echo7847's Avatar
Default Re: (jolt-tsp)
Use the cables for a 94 civic ex w/abs and they bolt up perfectly. I had the same problem and I bought the civic cables because the integra ones would not bolt up properly.
Old Apr 15, 2005 | 07:16 PM
cuz_ican's Avatar
Default Re: (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">Use the cables for a 94 civic ex w/abs and they bolt up perfectly. I had the same problem and I bought the civic cables because the integra ones would not bolt up properly.</TD></TR></TABLE>
yup yup
Old Apr 15, 2005 | 07:40 PM
civic94B18B1's Avatar
Which cables are you using ?
Old Apr 15, 2005 | 09:36 PM
cuz_ican's Avatar
Default Re: Rear Disc Brake Conversion Question (civic94B18B1)
95 civic w/ abs...but one of my friends made it work w/ the integra cables, by disconnecting the cables from caliper then mounting them onto the braket inside the car then putting it back on the caliper(this takes some muscle, you may need two people for this part) then add the brake lines last it will make the cable installation easier...
Old Apr 15, 2005 | 10:09 PM
Default Re: Rear Disc Brake Conversion Question (cuz_ican)
I found another way to do it... unbolt the 2 brackets underneath the car closest to the middle of the car. It gave it the perfect amount of slack.
Old Apr 15, 2005 | 10:21 PM
whitecat31's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic94girl &raquo;</TD></TR><TR><TD CLASS="quote">I found another way to do it... unbolt the 2 brackets underneath the car closest to the middle of the car. It gave it the perfect amount of slack. </TD></TR></TABLE>
AWESOME. Now don't just tease us with words. Show us some pics sometime soon please.
Old Apr 15, 2005 | 10:26 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: Rear Disc Brake Conversion Question (whitecat31)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitecat31 &raquo;</TD></TR><TR><TD CLASS="quote">
AWESOME. Now don't just tease us with words. Show us some pics sometime soon please.</TD></TR></TABLE>
What? If you're asking what I think you're asking, don't live by the "she's a woman, I'm a man, therefore I must e-f'k her because she has a unique soul working on Hondas".
