what do i need to do to put a jdm b16 sirII short block in my 99 civic si?
Old Apr 14, 2005 | 04:59 PM
spidermancivic's Avatar
Default what do i need to do to put a jdm b16 sirII short block in my 99 civic si?
my rings are gone in my usdm b16a2. thinking of putting a jdm sir II short block in. found one for a good price. what do i need to do?
TIA.
Old Apr 14, 2005 | 07:19 PM
uncle's Avatar
Default Re: what do i need to do to put a jdm b16 sirII short block in my 99 civic si? (spidermancivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spidermancivic &raquo;</TD></TR><TR><TD CLASS="quote">my rings are gone in my usdm b16a2. thinking of putting a jdm sir II short block in. found one for a good price. what do i need to do?
TIA.</TD></TR></TABLE>
Buy block. Have block installed.
Old Apr 14, 2005 | 10:25 PM
Default Re: what do i need to do to put a jdm b16 sirII short block in my 99 civic si? (uncle)
so i dont need to change out oil pumps or dizzy, alternator, or anything? direct bolt on? obd1 - obd2 stuff?
Old Apr 15, 2005 | 04:29 AM
uncle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spidermancivic &raquo;</TD></TR><TR><TD CLASS="quote">so i dont need to change out oil pumps or dizzy, alternator, or anything? direct bolt on? obd1 - obd2 stuff?</TD></TR></TABLE>
The blocks are essentially the same. You can take the stuff from you old block and put it on your new block.
Old Apr 15, 2005 | 04:53 AM
andyjt's Avatar
you need your usdm b16a2 oil pump. Doesnt it have a crank sensor in it that obd1 motors dont have?
Old Apr 15, 2005 | 10:11 AM
Default Re: (andyjt)
yes, i believe the crank sensor is on the oil pump. i will need to swap out oil pumps. anything else besides the oil pumps?
also, what about the 88-91 jdm b16a? is it the same as the sirII? just swap out oil pumps?
Modified by spidermancivic at 7:28 PM 4/15/2005
Old Apr 16, 2005 | 09:20 AM
egsleepercivic's Avatar
^less compression than the Sir2 10.4v10.2
Old Apr 17, 2005 | 03:09 PM
andyjt's Avatar
a jdm 88-91 b16a has the 2 prong coolant temp sensor/fan switch in the back of the block, while your stock harness has a plug type one in the thermostat housing.
Old Oct 12, 2007 | 12:18 PM
spoonek4's Avatar
Default Re: (spidermancivic)
Sorry for bumping a very old thread..........I just searched around & found this post which is closest to what I needed to know.
My friend has a Cdn spec 00 SiR(supposed to run OBD2B but he chipped & tuned it to run p28). He needs to rebuild his engine now. We like to find out :
- If we use the OBD2b 00Si/SiR oil pump from his old block is the ONLY thing needed to do in order to use a JDM/USDM obd1/obd2a short block??
Can he swap right back to his obd2b ecu in order to go for emission test?
- The bolt that bolt his crank pulley into his crankshaft is broken. In case he needed another crank, what would u guys suggest us to look for?
New aftermarket crank (Eagle makes them? Are they reliable for going up to 9000rpm a lot coz we do quite a bit of lapping events)? used oem crank? the whole used short block? How do we check for condition or damages etc?
- We have a B17a short block sitting around collecting dust. It used to go with a GSR head & had low compression but anyway. Should we make use of it?
What do we need to do in order to use that block? Which piston should we go for? Any side effect from using that?
Please let me know guys! Thanks!
trhoppe
Jun 5, 2006 03:24 PM
SIcivicHATCH
Jan 11, 2005 07:47 PM
drastikchangez
Nov 23, 2004 02:37 PM
done
Jan 5, 2004 02:42 PM
crxbust
Oct 16, 2003 04:40 PM
