crx with S2K cluster
Old Apr 14, 2005 | 04:56 PM
crxxor's Avatar
Default crx with S2K cluster
I know I've seen before, but I can't dig it up. I need a wiring diagram for the S2K cluster. Also, has anyone gotten the speedo to work? Any help would be greatly appreciated
Old Apr 14, 2005 | 05:08 PM
vtec y0's Avatar
Default Re: crx with S2K cluster (crxxor)
The one crx i saw it on was the k20 rex
Old Apr 14, 2005 | 05:30 PM
mr_valentino20032000's Avatar
Default Re: crx with S2K cluster (vtec y0)
there was another one that was done in europe on a b16 CRX i think. He said something baout how he plans to make an electrical "map" to show everyone how to install it.
damn i couldn't find it either
ok here it is http://board.hondacrx.co.uk/ph...23883
Modified by mr_valentino20032000 at 6:57 PM 4/14/2005
Old Apr 14, 2005 | 05:33 PM
SiR Inspired ED7's Avatar
http://www.jtuned.com/content/...eid=1
Old Apr 14, 2005 | 05:49 PM
steronz's Avatar
http://forum.pgmfi.org/viewtop...rt=45
that's the british one, but the site hasn't been updated in a while.
Old Apr 14, 2005 | 05:56 PM
crxxor's Avatar
Default Re: crx with S2K cluster (mr_valentino20032000)
As of now I have the 1.5 but there is a shop in town holding a B20 until I can scrounge up the last $500. That'll give people a run for their money.
Old Apr 14, 2005 | 06:58 PM
doublethink's Avatar
yes its been done, right now the speedo requires a custom piece that may not yet be made, or may never be made.
its all up to that guy in europe who successfully did it.
Old Apr 15, 2005 | 05:29 AM
crxxor's Avatar
Default Re: crx with S2K cluster (doublethink)
Thanks for all of the info, but this still leaves the question...does any one know where I can gat a S2K wiring diagram!!
Old Apr 18, 2005 | 05:16 AM
crxxor's Avatar
.....any help at all?
Old Apr 18, 2005 | 08:30 AM
drdisco69's Avatar
Try talking to a Honda dealer in your area and ask for photocopies of the manual. Get one for the EF while you're at it.
Old Apr 19, 2005 | 05:09 AM
crxxor's Avatar
Default Re: crx with S2K cluster (drdisco69)
They won't photocopy it for me, I already tried. They want me to by and $80 repair manual. And, I already mapped out my wires.
Old Apr 19, 2005 | 04:43 PM
drdisco69's Avatar
Well if they're going to be ******** about it...
-Link deleted-
Modified by drdisco69 at 11:18 AM 4/20/2005
Old Apr 20, 2005 | 05:16 AM
crxxor's Avatar
Man, you are now a god for me. If you every need parts from the FL leave a post. I deal with a few shops down here.
Old Apr 20, 2005 | 05:45 AM
drdisco69's Avatar
Haha, thanks. I worked at a Honda dealer, and I'm at an Acura dealer now, so I hate to see dealers get a bad rep. Glad I could help, let me know if there's anything else you need.
Old Apr 20, 2005 | 07:05 AM
crxxor's Avatar
You say that you do chipping...do I have to have the chip or do you sell chips.
Old Apr 20, 2005 | 07:13 AM
drdisco69's Avatar
I can make a chip to the specs you want. It's not a replacement for dyno tuning, but if you have different injectors, want a different vtec point or rev limiter, or need a conversion done I can do that for you. If you have a dyno with an AF graph, or some fuel controller settings, I can try to integrate that into the tune.
Old Apr 20, 2005 | 07:27 AM
crxxor's Avatar
did you already pull the page offline. I went to print it from favorites and it times out. Can you PM it to me again pls?
Old Apr 20, 2005 | 07:32 AM
drdisco69's Avatar
Sorry, I thought you had downloaded them. I'll PM you the link.
Old Apr 20, 2005 | 07:36 AM
crxxor's Avatar
no prob. I saved it (can't use the IM yet) thanks again. My car says thanks as well
Old Apr 20, 2005 | 07:37 AM
drdisco69's Avatar
Oh, I forgot, trial user. Here you go then:
-link deleted...again!-
Old Apr 20, 2005 | 07:38 AM
crxxor's Avatar
got it. Tnks
Old Apr 23, 2005 | 09:45 AM
crxxor's Avatar
anyone have a 1991 hf cluster diagram laying around?
Old Apr 23, 2005 | 02:22 PM
drdisco69's Avatar
http://www.coe.uncc.edu/~mdkeena/doc/HF/
Old Apr 25, 2005 | 05:51 AM
crxxor's Avatar
Is there anything you don't have! Got a question. Here's what I'm thinking, I have a 2001 S2K push button ignite, if I put a toggle switch on the ignition wire that will stop a reignite when someone pushes it, right?
Old Apr 25, 2005 | 08:38 AM
drdisco69's Avatar
Elaborate when you talk about a toggle switch. If you just have a switch in line that you turn off after you start the car, that will keep the button from starting it again until you switch it back on.
A better way would be to put a relay in there that cut power to the switch when the car was running. I'd have to look at the wiring diagrams but it shouldn't be too hard.
