need someone familiar with tuning power fc. PLEASE HELP
ok, here's the deal. my car is in the shop right now and just had a turbo put on, however i can't drive it because my injectors are 440cc and i can't do it with my stock obd2 ecu, but at the same time these guys dont have the software to tune a power fc. I've heard that you can tune it with just the fc commander. but is that correct or not? These guys are real good and know what they're doing when it comes to tuning, but i need to know is it do-able to tune with just the commander unit and wideband o2 and dyno. please let me know.
Thanks, Will
Thanks, Will
When tuning the Power FC for boost, it CAN be done by using the commander but will take about 10 hours to do because you can only access small sections of the map. If you have the FC datalogit for Honda turbo, the time is much easier. Strange.. I've had a couple of Power FC users w/ 440cc injectors with a stock head for N/A application, and the self-correcting mechanism works fine. Is Ground Zero tuning it?
I believe I also posted in some other areas about this as well.
i have it at a place called Turbo Technologies in Tacoma, WA. They have a **** load of experience tuning, just not with the power fc's, but i guess they've done a couple. I just need to be sure that it can be done and have no problems.
