Unorthodox Pulleys, CTR pulley, are they really bad?
Ok... I keep getting people telling me upgrading my pulleys is gonna screw up my B18C Type R motor. I've had the Unothodox pulleys on for about maybe 2K mi now.
So I went to the Unorthodox website and this is what they had to say about on their FAQ:
"Is my crank pulley a harmonic/torsional/vibration damper or a harmonic balancer?"
People are getting their crank pulleys confused with the harmonic dampers found on some V6 / V8 engines. "Harmonic Balancer" is a term that is used loosely in the automotive industry. Technically, this type of device does not exist. The "balancer" part comes from engines that are externally balanced and have a counterweight cast into the damper, hence the merging of the two terms. None of the applications that we offer utilize a counterweight as part of the pulley as these engines are internally balanced.
The pulleys on most of the new import and smaller domestic engines have an elastomer (rubber ring) incorporated into the pulley that looks similar to a harmonic damper. The elastomer in the OEM pulley serves as an isolator, which is there to suppress natural vibration and noise from the engine itself, the A/C compressor, P/S pump, and alternator. This is what the manufacturers call NVH (Noise Vibration & Harshness) when referring to noticeable noise and vibration in the passenger compartment. It is important to note that in these applications, this elastomer is somewhat inadequate in size, as well as life span, to act as an effective torsional damper. If you look at the pulleys on some of the imports there is no rubber to be found at all. We have samples of these, mostly from Acura/Honda, the Nissan Altima, 1.8L Eclipse, 2.3L Fords, Chrysler 2.2L's, and 1.8L VW's, to mention a few. This is not to say that with our pulleys you will hear a ton of noise or feel more vibration from your engine compartment. Most who have installed and driven a vehicle with our pulleys will notice the engine actually feels smoother. This is a natural result of replacing the heavy steel crank pulley with a CNC-machined aluminum pulley. NVH is variable and unique to every car. NVH will increase with the installation of an aftermarket intake and/or exhaust, for example. Think of OEM intake systems in newer cars, they use baffles and resonators in the intake to quiet all the intake noise. Aftermarket intakes eliminate these resonators and create dramatic increases in engine noise from the throttle opening and closing. So to most tuners, certain types of NVH can make the driving experience more enjoyable.
The purpose of a traditional harmonic damper is to protect against crank failure from torsional movement. This is not necessary in most modern engines because of the many advances in engine design and materials. Factors such as stroke, displacement, inline, V configurations, power output, etc., do determine when and how these harmonics and torsional movements occur.
Again, there is a lot of internet hearsay about the pulleys. When engine problems occur, too often people are quick to blame the pulley first, rather than taking the time to look logically into why there was a problem. We hope that after reading this you will understand the crank pulleys better.
"Will Unorthodox Racing lightened pulleys cause an oil pump failure?"
Urban myths have been floating around about Honda oil pumps failing by using an Unorthodox Racing crank pulley/s. The real fact is that these OEM pumps have been failing with AND WITHOUT the use of our pulleys and before our crank pulley/s were available on the market. Also note that these failures are few and far in between.
The Acura/Honda oil pumps are excellent units, but there are a number of reasons for the failures that do occur.
Most of the oil pump failures have been in Acura/Honda B series 1.6/1.8L applications. The Mazda 1.6/1.8L applications have seen a few failures, as well as the new Ford Focus ZETEC in race vehicles. Again, note that on all these applications the oil pump failures have occurred on engines not using our pulley, using the stock crank pulley.
These pump failures can be linked to the following causes. These causes may act individually or in combination to cause the actual failures:
The gears used in many pumps including those in the Honda B series engines and Mazda Miata engines are of a low-cost powdered metal composition. The factory uses this metal because of its acceptable cost-to-strength ratio. The problem is, these parts are not always deburred properly from the factory and when pushed to their limits can and do fail.
Many times additional stress is added to the oil pump by using oil thicker than what is specified by the manufacturer. The oil pump and bearing clearances were not designed from the factory to push oil of higher viscosities. This extra stress on the gears, combined with the above mentioned poor deburring process, can attribute to oil pump failure or engine failure.
Another contributing factor to oil pump failures is the weak cast backing plate of the B16/B18 oil pumps. Simple inspection shows that when compared to an H22 oil pump, a screw is not present in a critical location of the plate in the B series pumps. Compound this with the use of a higher viscosity motor oil and poorly deburred pump components and you have the ingredients for an oil pump failure.
This issue, specific to the Mazda 1.6/1.8L engines, involves the flex of the crankshaft and the lower half of the engine due to the additional stress of a forced induction system (such as a turbo or supercharger). The additional stress produced by forced induction causes flexing of both the block and the crankshaft between the front main bearing and the oil pump. This can also contribute to oil pump failure. Early Miatas were notorious for having crankshaft problems and later models suffered from problems as power is increased significantly.
Lastly, any failure inside a motor, related to aging components or a poor engine rebuild, can cause the oil pump to fail. ANY particles passing through an oil pump design such as that used in the Honda B series engines will cause damage or failure.
Remember that oil pump failures happen regularly on engines using a factory crank pulley. To help combat these failures, a few steps should be taken to help prolong the life of your oil pump and engine:
Unless building a race motor with race clearances in mind, you should always use an oil viscosity matching, or as close to the factory recommendations as possible.
If using a factory oil pump, always have your oil pump components deburred properly. It is recommended you have a competent engine rebuilder handle this.
For those who run dedicated / extreme race vehicles we recommend using an external wet or dry sump oiling system. These systems are designed for the heavy abuse a race engine receives on the track. Remember, the stock oiling systems were designed for factory horsepower levels and can only handle a certain amount of power increase over that level.
Lastly and most obvious, have a competent, trusted machine or performance shop rebuild your precious motor. It only takes one simple mistake to turn a costly engine rebuild into a doorstop.
If you have any other questions about this subject please don't hesitate to give us a call or drop us an e-mail. We take great pride in the craftsmanship of our products and are constantly striving to provide the highest quality products available to you, our customers.
"Will these pulleys cause premature engine bearing wear?"
This is a fear many prospective owners have and is a valid concern since we are dealing directly with the rotating assembly. Fortunately it is another urban myth with no basis in fact. The fact is that our pulleys have the opposite effect on engine bearings. The combination of tight tolerances, quality control, perfect balance, and dramatic weight loss versus the stock pulleys reduces stress loads on your engine, extending the total service life you can expect from your engine. Engine bearing problems are purely associated to poor engine maintenance, use of heavier than factory recommended oils, improper engine building practices (which includes poor balancing), excessively revving engines when they are cold, and owners expecting their factory oil pumps to handle engine power outputs beyond 3, 4, even 5+ times the stock power levels.
So is this bad or is this good?
use your own judgement, basically you have to give up something to gain power so from what you should understand from all this is half the people will tell you the pulleys cause damage and half the people will say they have been using them for years without an issue, nothing concreate has been proven to definitely prove they cause any type of wear or damage other than just human error or install issues.
I am thinking about getting a pair, one for my alt. and one crank. I was wondering if there was a diff. in the strengths of the offered colors. e.g.: is blue stronger then red? I have heard diff. things from diff ppl and just wanted another opinion.
Thanks and sorry for the noob ques.
gtowni3
Oct 15, 2004 08:29 PM
