need some help!!!!
Old Apr 14, 2005 | 03:01 PM
russian_accord's Avatar
Default :o motor swap help needed!!!!
im planning to do a swap on my 93 accord F22. i have 2 motors to choose from.It is the C27A, 24 valve 2.7 liter V-6 and or the C32A ACURA TYPE 2 230 H.P. 91-95 LEGEND MOTOR. i would like to find out if any of these would possebly fit my accord. if anyone can hook me up with some advice and or some websites where i could find out!!! im doing some reaserch but i cant quite find anything. so please help me out. i really want to try to do this swap. please hel ASAP
Old Apr 14, 2005 | 03:29 PM
Nick H's Avatar
New User
Default Re: :o motor swap help needed!!!! (russian_accord)
without extensively modifying your engine bay and front end, you aren't going to have very good luck fitting either of those motors in your car...the 95-97 v6 accords actually had a longer nose to accomodate the v6...
Old Apr 14, 2005 | 09:16 PM
Default Re: :o motor swap help needed!!!! (Nick H)
hey thanks! i found some info about that today, it is practicaly impossible, so im not even gonna try it. but thanks for the advice. hey and also what other motors could fit my 93 accord, i know that an h22 will fit and h23, but i want something stroinger. if you know what else their is that i kan swap, with/out to much cutting and welding!!!
Old Apr 15, 2005 | 01:16 AM
Nick H's Avatar
New User
what do you mean by stronger? if you are talking more power, just boost your stock motor...if you blow it, they are real cheap to replace...in terms of swaps though, you are basically stuck with the h22/h23 choices (that is for an easy fitment)...other than that, you could always try the k24 or something of that nature, but the fabrication and fitment issues probably wouldn't make it a worthwhile swap...i'd personally just boost your stock motor though...
Old Apr 15, 2005 | 05:27 AM
97SOHCF22B2VTEC's Avatar
I agree, with Nick H. Boosting your current F22 is better choice. F22 can handle a few lbs of boost on stock internals.
Old Apr 15, 2005 | 05:33 AM
THEROPE's Avatar
Default Re: (97SOHCF22B2VTEC)
the problem you are going to have with swaping the v6 is the axles
the v6 accords like said before have a longer bay and the v6 is listed as a mid engine car because of the axle placement
what you should do is swap in the (if swaping is your thing) f22b dohc jdm motor,
the h22 dohc vtec motor or the h23 nonvtec dohc usdm motor.
but if you want to keep the block you have now boost it,
cast iron blocks love boost
Old Apr 15, 2005 | 11:40 AM
Default Re: (THEROPE)
alright!! but see i know i can drop a h22 in my accord without cutting and welding. but i heard that if you do that swap you need to change a few parts. i want to know what they are. if you know what i will have to modify please tell me. cuz i was told that if i stick the H22 in i might have to change my steering rods, and that im gonna need the rubber peices that go on the prelude mounts. Is it true or Falce??
jondrethegiant
Feb 6, 2007 05:07 AM
rex855
Sep 9, 2005 09:54 AM
Mike95lude
Feb 4, 2004 03:16 PM
