Transmission Removal & Install
Old Apr 14, 2005 | 02:44 PM
97CivicDad's Avatar
Default Transmission Removal & Install
My sons clutch just went out on his 97 Civic with a B18B1 Engine from a 95 Integra LS. I have all the tools, but I was wondering if anyone has a procedure on how to remove and install a 5-speed on this car. I've done tranny's on rear wheel drive cars and trucks, but was concerned if this is something I can do in my garage? Do I need to have any special engine supports from the top of the car? Any info would be appreciated?
Thanks,
Ron
Old Apr 14, 2005 | 02:56 PM
civiccpedx's Avatar
Default Re: Transmission Removal & Install (97CivicDad)
if you have done trannies in rear wheel drive, this should be a piece of cake. A few friends and basic tools and it should be out and in, in just a few hours.
Old Apr 14, 2005 | 03:15 PM
pdiggitydogg's Avatar
very easy, but check this out if you want a step by step w/ pictures
http://www.honda-acura.net/for...15569
Old Apr 14, 2005 | 06:27 PM
HiProfile's Avatar
Default Re: (pdiggitydogg)
Depending on how long ago it was swapped, you might want to spray the hell out of the axle splines in the hub with penetrating oil. It took 3 days (working till I was ready to break something) of spraying, heating, and pounding to get my ls axles out of my eg. Turned out one boot recently ripped, and the other was almost cracked open too. When I had to yank the tranny on my 88 teg I didn't have air tools for the axles, so I just unbolted the stocks and yanked them out till they pulled out of the tranny. Not sure if you can do that in an eg w/ls, since there was almost no room left.
laziebun
Acura TL, RL & ZDX
Feb 21, 2010 06:26 PM
kornerk12
Aug 8, 2008 08:32 PM
ladyJspec
Jan 29, 2007 02:50 PM
SpoolnEG6
Sep 21, 2005 09:40 AM
david90
Jun 8, 2004 02:47 PM
