wheres the ecu on an 88 civic hatch?
Old Jan 29, 2002 | 07:07 PM
inzane's Avatar
Default wheres the ecu on an 88 civic hatch?
does anyone now where i can find the ecu on 88 civic hatch
Old Jan 29, 2002 | 07:10 PM
EP3_05's Avatar
Default Re: wheres the ecu on an 88 civic hatch? (juncivic)
Pull up the carpet in the passenger footwell. Remove the 4 10mm nuts holding the metal ecu cover down. Remove the metal plate and voila there is the ecu. hth
Old Jan 29, 2002 | 07:11 PM
the DR.'s Avatar
most likely mounted up against the firewall or right where the passenger seat would put his/her feet at. like right where the floor curves up into the dash, pull out the carpet right there and there should be a plate (goldish, yellowish) that covers the ecu
aw beat me to it!
[Modified by CIVICtypeS, 4:12 AM 1/30/2002]
Old Jan 29, 2002 | 07:38 PM
psicrxsi's Avatar
passenger side where yer feet go....lift up that carpet and low and behold...there it is
Old Jan 30, 2002 | 06:05 PM
maximedx's Avatar
Default Re: wheres the ecu on an 88 civic hatch? (psicrxsi)
yes it's on the passenger side.remove the carpet and you find it
natesfresh
Feb 23, 2008 10:18 PM
rolledthatho
Aug 11, 2005 11:17 PM
sickofitall1113
Jun 13, 2005 11:21 AM
vbspec
Apr 8, 2004 03:56 PM
Hondasaurs
Mar 18, 2002 10:31 AM
