camber kits?
Old Apr 14, 2005 | 12:45 PM
deez nuts's Avatar
Default camber kits?
rear tire is cambering really bad..... whats the cheapest way to correct this problem? washers?
Old Apr 14, 2005 | 04:05 PM
t o m's Avatar
Default Re: camber kits? (deez nuts)
just get the camber kit
Old Apr 14, 2005 | 04:49 PM
kung fu grip's Avatar
washers won't work they did on older hondas. look for a set of used camber UCA if you're in a pinch.
Old Apr 14, 2005 | 04:50 PM
t o m's Avatar
Default Re: (kung fu grip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kung fu grip &raquo;</TD></TR><TR><TD CLASS="quote">washers won't work they did on older hondas. look for a set of used camber UCA if you're in a pinch. </TD></TR></TABLE>
yea. i got vision UCA's solid construction
Old Apr 14, 2005 | 07:43 PM
1337 Si's Avatar
Default Re: (integra type s)
I just dropped the wifes EP3 on Teins and I used the Ingalls kit. It was at like -2.8 degrees negative too.
HyRev
Suspension & Brakes
Aug 20, 2008 06:19 PM
crawlin
Suspension & Brakes
Aug 24, 2006 01:06 PM
integraver
Sep 19, 2005 04:24 PM
JDR
Suspension & Brakes
Jun 6, 2005 04:18 PM
jdmrota
Suspension & Brakes
Mar 18, 2005 09:06 AM
