je gsr pistons b20 block
Old Apr 14, 2005 | 12:31 PM
ilsimsli's Avatar
Default je gsr pistons b20 block
i have je 12to1 pistons would they work in a b20 block with a b16 head for a b20 vtec setup and what would the compression be also would i be able to use them in a b16 block with the b16 head and what would that compression be
and yes i have searched no b20 with je gsr high comp pistons
thanks
Old Apr 14, 2005 | 01:31 PM
doood's Avatar
been there done that
Default Re: je gsr pistons b20 block (ilsimsli)
what size are the pistons? 84mm pistons will not fit into a stock b16 block and 81mm will not fit into a b20 block.
Old Apr 14, 2005 | 01:59 PM
butters's Avatar
Default Re: je gsr pistons b20 block (sticky icky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sticky icky &raquo;</TD></TR><TR><TD CLASS="quote">what size are the pistons? 84mm pistons will not fit into a stock b16 block and 81mm will not fit into a b20 block.</TD></TR></TABLE>
yeah, first you have to get the right size pistons
Old Apr 14, 2005 | 08:37 PM
ilsimsli's Avatar
Default Re: je gsr pistons b20 block (butters)
sorry about that there 81
Racer9999
Feb 3, 2016 10:17 PM
jdmEF8racer
Mar 21, 2007 09:11 AM
ALLMOTOR CRX
Mar 13, 2007 01:47 PM
ZedEx
11
Jul 10, 2005 09:18 AM
vti2
Dec 2, 2003 04:28 PM
