92 Civic Sqeals and Screams when starting up!!! Help My Honda Peeeeps!!!
Old Apr 14, 2005 | 12:16 PM
DBLAZE's Avatar
Default 92 Civic Sqeals and Screams when starting up!!! Help My Honda Peeeeps!!!
As the post says...when I start up my car in the morning or after it has been sitting for an hour or longer, it makes this awful screaming/squealing noise and after about 5-10 seconds it goes away. Its been doing this for some time now. I check my belts and they seem fine (no cracking or fraying), any suggestions on what this could be???? And it happens with no AC on and it is coming from under the hood..ll
Old Apr 14, 2005 | 12:25 PM
civictildeath's Avatar
Default Re: 92 Civic Sqeals and Screams when starting up!!! Help My Honda Peeeeps!!! (DBLAZE)
check the power steering fluid.
could be a bearing going on one of the pulleys also
Old Apr 14, 2005 | 12:49 PM
ssbpturbohatch's Avatar
Default Re: 92 Civic Sqeals and Screams when starting up!!! Help My Honda Peeeeps!!! (civictildeath)
just looking at the belts wont let you know all the time if they are bad, try spraying a little belt dressing on them one at a time before you start it up next time just so you can be for sure, if it helps then change the belt(s). Hope my $.02 helps
Old Apr 15, 2005 | 06:19 AM
jeef84's Avatar
Default Re: 92 Civic Sqeals and Screams when starting up!!! Help My Honda Peeeeps!!! (ssbpturbohatch)
A method that has always worked for me is to use wd-40 on the pulleys, one at a time, while turning the car on and off. Once you locate which pulley the noise is coming from, you know which belt/pulley to change, and hopefully the wd-40 temporarily eliminates that awful noise.
Old Apr 15, 2005 | 06:26 AM
b204dr's Avatar
i didnt have any power stearing or ac ! limited choices and i had this - swapped all my belts out and it was gone- there might be wear in certain portions of the belt not visable at quick slight glance -
Old Apr 15, 2005 | 09:53 AM
DBLAZE's Avatar
Default Re: (b204dr)
Thank you guys very much for all your help and fast info. All it was was a belt adjustment. My alternator belt was just a little bit loose. I used a wrench to adjust the screw that allows you to adjust the belt....It works perfectly now....No more noise!!!!
Old Apr 15, 2005 | 11:05 AM
Default Re: (DBLAZE)
good job, squeels suck
Old Apr 15, 2005 | 11:11 AM
cwin's Avatar
your belts could have been slippin?? just a though
bwhite94
Honda Civic (2006 - 2015)
Jul 29, 2017 12:13 PM
75aces
Aug 1, 2011 10:23 PM
jay24k
Nov 15, 2008 02:58 PM
w0ng_sta
May 21, 2006 10:49 AM
808style
Jul 31, 2003 12:37 AM
