White Smoke + Bogging and Stuttering = ?
Old Apr 14, 2005 | 11:35 AM
Civic Hx-T's Avatar
Default White Smoke + Bogging and Stuttering = ?
Bad head gasket?
It's an all the time thing, now. Not just when I start it up and the spark plugs are white.
I'm going to check the radiator now.
Old Apr 14, 2005 | 11:43 AM
sohcvtec1995's Avatar
Default Re: White Smoke + Bogging and Stuttering = ? (Civic Hx-T)
yea sounds like headgasket.
Old Apr 14, 2005 | 11:44 AM
.BigSexy's Avatar
most hood white kid
Default Re: White Smoke + Bogging and Stuttering = ? (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">yea sounds like headgasket.</TD></TR></TABLE>
I second that....changed mine back in November
IHateJDM's Avatar
headgasket
Old Apr 14, 2005 | 12:09 PM
DBLAZE's Avatar
Default Re: White Smoke + Bogging and Stuttering = ? (IHateJDM)
No question...It is definitely the HEAD GASKET....be prepared to DIY or pay like $400.....
Old Apr 14, 2005 | 12:11 PM
Civic Hx-T's Avatar
The oil looks fine and so does the coolant.
The car isn't overheating at all. It's just stuttering and blowing out white smoke.
If I cut the car off, while driving, wait and then cut it back on then it's fine again.
I don't get it.
I already changed out the ECU's, both are working just fine.
Old Apr 14, 2005 | 12:21 PM
IHateJDM's Avatar
Default Re: (Civic Hx-T)
white smoke is coolant, blue smoke is oil. change your headgasket before it starts to overheat, and you warp your head.
Old Apr 14, 2005 | 01:49 PM
komat's Avatar
Default Re: (IHateJDM)
weee i have the same problem
i have to fill up my coolant every day
it can only drive for like 20min max b4 major smoke comes out and overheating
since all my coolant is burning or leaking out i use 80% water 20% coolant
Old Apr 14, 2005 | 01:58 PM
IHateJDM's Avatar
Default Re: (komat)
unless you think it's likely that it's gonna freeze soon, I would be using 100% water until you fix that headgasket.
Old Apr 14, 2005 | 02:15 PM
Farmer Brown's Avatar
One more vote for headgasket. Although you more often see smoke in turbo applications. Hmmm..
And boy oh boy do those smoke. Esp in race applications.
Old Apr 14, 2005 | 04:20 PM
kkim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic Hx-T &raquo;</TD></TR><TR><TD CLASS="quote">
I'm going to check the radiator now.</TD></TR></TABLE>
So, did you check the coolant level and does it drop after you fil it up? If so, then I'd agree on the headgasket. Although, if it were the headgasket, I'd think you would have water in oil/ oil in water.
If you're not losing any coolant, you may have another problem. White smoke could also mean you're running way too lean. Have you checked your timing?
Old Apr 14, 2005 | 04:25 PM
Ricochet.'s Avatar
Head gasket. Fix it ASAP or you'll be replacing an engine..
Modified by Ricochet. at 9:05 PM 4/14/2005
Old Apr 14, 2005 | 04:43 PM
PureBlood's Avatar
White Smoke - Water Based
Blue smoke - Oil Based
Change your oil, flush your rad, if you still can't figure it out, pop the head and take a look.
Old Apr 14, 2005 | 05:15 PM
legoman's Avatar
headgasket
civ97
Mar 31, 2009 07:56 PM
ELSUICIDA
13
Apr 4, 2007 06:07 PM
gmboogy
Nov 29, 2006 01:44 AM
mcgee*
11
Feb 22, 2006 07:36 AM
Layziebtnh055
10
Apr 16, 2004 02:22 PM
