Need help on finding a L shape polished pipe 4 my rad hose
Where can I find a L shaped pipe with the same size diameter pipe as a stock upper rad hose on a 91Teg? Just the pipe, it looks like this. Its not for my teg but for my GN, but its the same diameter for the upper rad hose. Say 20 inches by 20 inches. The problem I have been facing is, my cold air pipe feeding the turbo is 4" and the upper rad hose sits inbetween the cold air pipe and the waterpump pulley. So the upper rad hose sometimes catches the water pump pulley and slices my rad hose open pouring coolant everywhere.
Try contacting some of the guys on here that make manifolds like in the sponsors section or in the welding forum? Someone in either of those two forums should be able to help
i have a pipe here at my work that is just like the one you have pictured. it isnt polished but you can polish it. it is made of alumnium. but i dont know the OD that you need. let me know i will sell it to you cheap. kind of.
sasinorm01
Feb 15, 2011 06:08 PM
hmtcrxsir
Apr 26, 2010 08:23 PM
