My Car screams/squeals and vibrates when the A/C is on
Ok When the car is idling or coming to a stop and the a/c is on the inside dash vibrates and it gets really bad when the fan comes on.
Also when im driving with the A/C on ill hear this loud screetching sound like fingernails on a chalk board coming from the car, the higher fan speed the louder it gets and longer it lasts. I recently put an A/C belt on the car to get the ac going and it just goes to the crank , compressor, and tensioner. Could this be a culprit. Its really embarrassing.
the fan is bolted up.
Ive noticed a lag in performance evan with the A/C off since i put the belt on.
So should i tighten it or loosen it?
Could bad grounds cause any of this
yeah if the compressor is shot it's going to put a massive load on that belt making it squeel even if it is the correct tension. that also puts hella strain on your engine, making the idle drop to shaking speeds (500rpm-)
Get a new compressor
m1ndless
May 17, 2007 06:20 PM
