Anyone recently had injector problems with 6th gen 4cyl?
It Wasn't Me!
Here in WA state several dealers I've talked to said they've suddenly been seeing quite a few bad injectors on 4cyl 6th gens in the past 2 weeks or so. Mileage does not seem to matter which seems to point towards a fuel quality problem rather than a manufacturing problem. One common factor appears to be the use of cheap gas. for example Arco, costco, or Walmart. If you or anyone you know have had injector problems please post when and what type (brand) gas you use.
If there's a problem with gasoline, remember that refineries are regional. Walmart gas in Seattle isn't coming from the same refinery as Walmart in FLA.
So people posting about this should say where they're located.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasean »</TD></TR><TR><TD CLASS="quote">Here in WA state several dealers </TD></TR></TABLE>
another one today... cust states only using chevron/shell fuels....
Modified by solo2slocivic at 11:28 AM 4/14/2005
It Wasn't Me!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">If there's a problem with gasoline, remember that refineries are regional. Walmart gas in Seattle isn't coming from the same refinery as Walmart in FLA.
Thanks, I meant to include that.
crxforum
Jan 17, 2004 01:53 PM
ActiveAero
Jul 3, 2003 11:27 AM
