quick header, cat, exhaust question
Old Apr 14, 2005 | 07:55 AM
ecks_fourttwo's Avatar
Default quick header, cat, exhaust question
im going to be getting a high flow cat for my 96 teg but i have 95 engine...so i got 95 headers....and a 96 cat-back exhaust.....my question is....
which year high flow cat do i get???? 96 or 95
or are they in the same year spand???
Old Apr 14, 2005 | 09:25 AM
ImportAutoPerformance.com's Avatar
Default Re: quick header, cat, exhaust question (ecks_fourttwo)
The cat should be the same on all 94-01 (exc. type-R).
Old Apr 14, 2005 | 10:13 AM
RuskeR's Avatar
94-97 cat
Old Apr 14, 2005 | 10:14 AM
purplegsr's Avatar
Default Re: quick header, cat, exhaust question (peteriap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peteriap &raquo;</TD></TR><TR><TD CLASS="quote">The cat should be the same on all 94-01 (exc. type-R). </TD></TR></TABLE>
Nope, they are slightly different depending on the year and model.
Do you have a gsr or non-vtec model?
If you have a 95 GSR, the cat length should be the same as the 96 GSR cat, however, I think the 96 cat will have an extra o2 bung (obd2 vs obd1, of course, that is easily solved if you just plug the 2nd bung). They will be the same length though.
If you have a 95 LS, you need a 94 or 95 LS cat, because they have no o2 bung at all, because the o2 is located on the collector of the header. The 96-01 LS, as well as the 00-01 GSR and ITR will have 1 o2 on the header, and 1 o2 on the cat.
Old Apr 14, 2005 | 11:06 AM
Default Re: quick header, cat, exhaust question (purplegsr (Exospeed))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr (Exospeed) &raquo;</TD></TR><TR><TD CLASS="quote">
If you have a 95 LS, you need a 94 or 95 LS cat, because they have no o2 bung at all, because the o2 is located on the collector of the header. The 96-01 LS, as well as the 00-01 GSR and ITR will have 1 o2 on the header, and 1 o2 on the cat.</TD></TR></TABLE>
non vtec (LS)
engine: 95 LS b18b1 obd1
car: 96 LS obd2
Old Apr 14, 2005 | 11:13 AM
purplegsr's Avatar
Okaaay, let me see if I can do this puzzle in my head.
All 94-01 LS have the same exhaust, cat, and header length. The only difference is that 94-95 will have 1 o2 in the header, and none in the cat, while 96+ will have 1 o2 in the cat and 1 o2 in the header. Since you are obd1, your LS header with the existing o2 bung will do the job, so you could use any 94-01 LS, 00-01 GSR, or 97-01 ITR cat (length is same), and just make sure that it doesn't have an o2 bung at all or that it is welded/plugged for you. The safe bet is to just get one for a 94-95 LS, but you could also get a 96+ and plug it or hope it comes without a bung already.
immalooser
Jul 21, 2007 08:11 PM
eddiedeader
Oct 30, 2006 05:24 PM
13HYBRID20
Apr 17, 2005 09:40 AM
Ghetto Civic HX
13
Nov 3, 2004 11:49 PM
SPLNRSX
Nov 10, 2003 01:55 PM
