anything else I should do while installing a LSD in y1 cable?
Old Apr 14, 2005 | 07:08 AM
HT Chaplain's Avatar
Loved
Default anything else I should do while installing a LSD in y1 cable?
Im getting ready to instal my LSD and was wondering if I should do anything while Im inside the tranny? maybe switch out the fifthgear or final drive? Let me hear your suggestions
Old Apr 14, 2005 | 07:39 AM
95lstegman's Avatar
Default Re: anything else I should do while installing a LSD in y1 cable? (HT Chaplin)
overhaul it. see sig
Old Apr 23, 2005 | 11:01 AM
drussell4801's Avatar
Default Re: anything else I should do while installing a LSD in y1 cable? (95lstegman)
yeah, overhaul is a good idea. Synchros at least.
also, I would suggest putting an LS 5th gear in there for gas mileage. Unless you plan on racing your car above 115mph. Y1 4th gear at 8000 rpm is 115, which means in a race situation, you wouldn't use fifth unless you were going faster than 115mph. If you're doing that, I would keep praying.
B16Blake
Jul 19, 2010 01:06 AM
aaronhume
14
Apr 30, 2006 09:59 AM
Lsos
Feb 23, 2006 09:22 AM
Skinny_REX
Jan 21, 2006 02:24 PM
