B18 Turbo - going over 6k and battery light comes on???
Old Apr 14, 2005 | 06:47 AM
Burke's Avatar
Banned
Default B18 Turbo - going over 6k and battery light comes on???
just stuck a b18 turbo in my hatch this weekend, all is well except a couple things
1. If i go up to 6000 rpm my battery light flickers and it breaks up
even if i free rev it a stop, if it go over 5.5k the light flickers
WEIRD? alternator maybe?? i've put a couple different dizzy's on it to no avail
2. rebuilt the bottom end, stock rods pistons, honed it, hastings rings and acl bearings. almost have 100 miles on it and still smokes like crazy. are my rings misaligned? i havent done a comp check yet
thanks for the help
burke
Old Apr 14, 2005 | 07:18 AM
RACINTWEEK's Avatar
your alt belt is loose, 2 min fix
do the comp test and post results
Old Apr 14, 2005 | 10:31 AM
Burke's Avatar
Banned
Default Re: (RACINTWEEK)
cool, i will check the alt belt tonight and do a comp test this weekend.
THANKS for the help!
Old Apr 19, 2005 | 10:51 AM
Burke's Avatar
Banned
Default Re: B18 Turbo - going over 6k and battery light comes on??? (Burke)
replaced the alt belt and seems to work better, but if i do rev high the red batt light will flash and the car will break up some. does this sound like symptoms of bad alternator??
smoking issues is still there.
does not smoke on start up only after it gets warm.
Really smokes at light throttle (high vac) and at idle. I know its oil
compression check came back at 205, 185 190 185 so they have seated. also changed the oil and plugs and both look good. tried some ring sealer **** from autozone. didnt smoke any less
also my pcv valve us not hooked up. any more suggestions
I am thinking maybe valve guide seal cause they have not been replaced, maybe my seal is bad on turbine housing, or a jacked up oil ring
thanks for the help im making another thread on the burning oil
THankS
Old Apr 20, 2005 | 04:55 AM
Burke's Avatar
Banned
bump
Old Apr 20, 2005 | 06:21 AM
RACINTWEEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">replaced the alt belt and seems to work better, but if i do rev high the red batt light will flash and the car will break up some. does this sound like symptoms of bad alternator??
THankS </TD></TR></TABLE>
with a new belt helping i wouldnt think its the alt itself, go to auto zone and have them test for you (free!!!)
compression looks good, lots of things could cause smoking, pull off your DP and see if there is any oil in the turbine housing
Old Apr 20, 2005 | 09:52 AM
Burke's Avatar
Banned
Default Re: B18 Turbo - going over 6k and battery light comes on??? (RACINTWEEK)
can i just take my car up to autozone or do i need the alt off it??
and takled to EE_chris and he is thinking voltage regulator and now i am too
im gonna see if i can pull the one of a d-series alt and see if it will plop into my b18a one which is from obd0
thanks for everyones help and suggestions
SwagNationEK9
Dec 2, 2013 04:22 PM
hybrid1990crx
29
Dec 21, 2012 01:48 AM
ElCivic89
Mar 27, 2012 08:23 PM
p1driftfiend
Jan 7, 2005 11:28 PM
xsellxoutx
Apr 23, 2004 02:52 PM
