Q for RC51 owners?
I rode one around for a couple days while a friend of mine was out of town (let me borrow it), they are very uncomfortable for just cruising or daily driving purposes. But they are a fun bike regardless. Lots of torque, and they are nimble, would make a great track bike. I'd never own one to drive on the streets though. My $.02
I've never heard of any mechanical/electrical problems with the RC51.
Good luck.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Etylorcen »</TD></TR><TR><TD CLASS="quote">Its definately not a great comuter bike. Its not very comfortable and with its side mounted radiators it can overheat in traffic. </TD></TR></TABLE>
was just gonna say...if you live where lane-splitting is illegal, its gonna overheat on ya
Depending on your weight, have the front forks revalved and sprung properly, ditch the rear shock and get a double clicker from ohlins.
Exhaust - Sato or Arrow duals
PC3R is a must
You can get a corbin seat for more comfort, but the seat makes the bike sit taller.
Do the radiator mod to keep the cooling up to par.
Otherwise, great bike to own!
PC3R is a must
What everyone hasn't mentioned so far is that the heat buildup roasting your thighs is quite welcome on cold nights.
I had a chance to ride one of these, and it is much different from my SuperHawk. If you find a good deal on one, snap it up. If you find another good deal, let me know.
I would not get 2000, look for at least 02+ or sp2. I hope this helps you out, I looooooooove my RC.
Here is some info:
Plastics/Paint Scheme differences:
- 00, 01, and 02 are the same
- 03 has black tail, less black on front cowl, and the entire "honda wing" fits on
the side cowls. Tanks has slight differences. Pictures below for 00-02 vs. 03 differences.
- 04 generally same as 00-02 except it has white "number plates" instead of black (and an unpainted frame - as noted below by RC-Rick)
Mechanical/component differences 02 & up as compared w/ 00-01:
- longer, re-designed swingarm
- improved FI & larger throttle bodies
- lighter 5 spoke wheels (6 spoke on 00-01)
- Slip on exhaust for 00-01 only fits 00-01 and 02 & up slip-ons only fit 02 & up.
- There are other minor changes not really that important to your choice (relocated oil cooler, taller stock windscreen, etc.)
Here's the detail pics of 00-02 vs. 03 paint schemes...
The above info is courtesy of dhdrider from another board.
The below info is courtesy of geremy from another board.
Part
Difference
Reason for Change
Forks
Lighter Staunchion Tubing, Softer Damping
Stiffer, more compliant
Front Axle
Heavier
Change front/rear weight bias
Front Brake Discs
Thickness increased from 3.5mm to 4.0mm
Prevent warping
Front Caliper Hangers
Different Design
Front Calipers (???)
Piston Coating (???)
Smoother action, better feel, less drag
Front Brake Master Cylinder
19 to 17 mm
Better feel
Front Wheel
5 Spoke
Lighter
Steering Stem
Larger
Stronger
Steering Stem top nut
Increased to 41 mm (previously 32 mm)
Stronger
Frame
Different engine hangers, swingarm pivot
Lighter, Stronger
Throttle Bodies
Increased from 54mm to 62mm
Better throttle response, more top end power
Velocity Stacks
Size Increase
Air Filters
Beneficial restrictor in left filter
Injectors
New 12 hole design (previously 4 hole)
Better fuel atomization
ECU
32-bit CPU (previously 16-bit)
Cooling System
Fan for each radiator, relocated oil cooler
More efficient cooling system
Seat Undertray
Redesign, ECU location change
Better underseat arrangement
Swingarm
Complete redesign, longer, lighter
Better rear grip and feel
Swingarm Pivot Inserts
different (?)
Rear Brake Hanger
different (?)
Chain
Longer
Length increased to accommodate longer swingarm
Rear Wheel
5 spoke
Lighter
Rear Shock
Relocated resevoir, softer damping
Easier to route exhaust, more compliant
Windscreen
Higher
Better wind protection
Windscreen bolts
Cheaper black plastic
Cost
Exhaust port shape
Now heart shaped (previousy round)
more efficient
Exhaust Header
re-shaped
More efficient/Lighter/More top-end
Exhaust Cans
Redesign/Lighter
Lighter
Rear Mudflap
Redesign
Spark Plugs
Different Part #s
Emissions? Longevity?
Clutch
First Friction Disk has larger Diameter, addition of Judder Spring
Better Clutch Action
Here is some info:
Part
Difference
Reason for Change
Forks
Front Axle
Heavier
Front Brake Discs
Prevent warping
Different Design
19 to 17 mm
Better feel
Front Wheel
5 Spoke
Lighter
Steering Stem
Larger
Stronger
Stronger
Frame
Lighter, Stronger
Throttle Bodies
Velocity Stacks
Size Increase
Air Filters
Injectors
ECU
Cooling System
Seat Undertray
Swingarm
different (?)
Rear Brake Hanger
different (?)
Chain
Longer
Rear Wheel
5 spoke
Lighter
Rear Shock
Windscreen
Higher
Windscreen bolts
Cost
Exhaust port shape
more efficient
Exhaust Header
re-shaped
Exhaust Cans
Redesign/Lighter
Lighter
Rear Mudflap
Redesign
Spark Plugs
Different Part #s
Clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArmyGreenITR »</TD></TR><TR><TD CLASS="quote">Good info
f#$k it i am looking for a RC i want a '02 now!
What is the radiator mod?</TD></TR></TABLE>
I don't see what the big deal is with these bikes.
Aside from the heavenly sound, of course. They're heavy as all hell, but from what a friend of mine told me, the front end is really skittish and you need to lean over the tank to get some weight over it.
For similar money, you could have an R1 or REPSOL. Duh...RC-what? I'd rather have a Super Chicken
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backlash »</TD></TR><TR><TD CLASS="quote">I would not get 2000, look for at least 02+ or sp2. I hope this helps you out, I looooooooove my RC.
Here is some info:
Part
Difference
Reason for Change
Forks
Front Axle
Heavier
Front Brake Discs
Prevent warping
Different Design
19 to 17 mm
Better feel
Front Wheel
5 Spoke
Lighter
Steering Stem
Larger
Stronger
Stronger
Frame
Lighter, Stronger
Throttle Bodies
Velocity Stacks
Size Increase
Air Filters
Injectors
ECU
Cooling System
Seat Undertray
Swingarm
different (?)
Rear Brake Hanger
different (?)
Chain
Longer
Rear Wheel
5 spoke
Lighter
Rear Shock
Windscreen
Higher
Windscreen bolts
Cost
Exhaust port shape
more efficient
Exhaust Header
re-shaped
Exhaust Cans
Redesign/Lighter
Lighter
Rear Mudflap
Redesign
Spark Plugs
Different Part #s
Clutch
Better Clutch Action</TD></TR></TABLE>
best response ever
Here is some info:
Part
Difference
Reason for Change
Forks
Front Axle
Heavier
Front Brake Discs
Prevent warping
Different Design
19 to 17 mm
Better feel
Front Wheel
5 Spoke
Lighter
Steering Stem
Larger
Stronger
Stronger
Frame
Lighter, Stronger
Throttle Bodies
Velocity Stacks
Size Increase
Air Filters
Injectors
ECU
Cooling System
Seat Undertray
Swingarm
different (?)
Rear Brake Hanger
different (?)
Chain
Longer
Rear Wheel
5 spoke
Lighter
Rear Shock
Windscreen
Higher
Windscreen bolts
Cost
Exhaust port shape
more efficient
Exhaust Header
re-shaped
Exhaust Cans
Redesign/Lighter
Lighter
Rear Mudflap
Redesign
Spark Plugs
Different Part #s
Clutch
best response ever
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross R »</TD></TR><TR><TD CLASS="quote">
Not sure what it is ive ridden an RC once an ive spent some time on an R1 also,the RC just seemed to lean into corners very easly,an i just enjoyed the over all "feel" of the bike(then again ever bike leans with less effort compared to my 600rr) an yes the sound is heavenly for sure.I also like them cause its diffrent you dont see 100 of them on the road.Plus im taling about getting a used one not brand new,so it would be cheaper then REPSOL 1000rr.Idealy I would like to try to keep my 600rr for track an have an RC for the street but i dunno i have to see about my new job,an selling my ITR.
</TD></TR></TABLE>Not sure what it is ive ridden an RC once an ive spent some time on an R1 also,the RC just seemed to lean into corners very easly,an i just enjoyed the over all "feel" of the bike(then again ever bike leans with less effort compared to my 600rr) an yes the sound is heavenly for sure.I also like them cause its diffrent you dont see 100 of them on the road.Plus im taling about getting a used one not brand new,so it would be cheaper then REPSOL 1000rr.Idealy I would like to try to keep my 600rr for track an have an RC for the street but i dunno i have to see about my new job,an selling my ITR.
Not sure what it is ive ridden an RC once an ive spent some time on an R1 also,the RC just seemed to lean into corners very easly,an i just enjoyed the over all "feel" of the bike(then again ever bike leans with less effort compared to my 600rr) an yes the sound is heavenly for sure.I also like them cause its diffrent you dont see 100 of them on the road.Plus im taling about getting a used one not brand new,so it would be cheaper then REPSOL 1000rr.Idealy I would like to try to keep my 600rr for track an have an RC for the street but i dunno i have to see about my new job,an selling my ITR.</TD></TR></TABLE>
its interesting that you find an rc leans easier than your 600rr because i noticed the same thing about the 929 after riding it some more....odd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross R »</TD></TR><TR><TD CLASS="quote">I don't see what the big deal is with these bikes.
You sorta have to be a weirdo to own/want one of these bikes. Most owners will tell you the same. I wanted another twin......and I didn't want another SV (650 or 1000). I've wanted an RC for the longest time anyway
Yes the bike is heavy, when your going slow, but when your at speed you don't even notice the weight of the pig. The front can get a little light when accelerating, especially if you have changed the gearing to 15/41, helps getting out of corners faster, but just like anything else it takes getting used to.
For similiar money you prob could buy an R1 or REPSOL.................but you would be "just another sportbike".... (not bagging on other bikes or I4's)
And the sound of this beast!!!! It's almost orgasmic
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectF4 »</TD></TR><TR><TD CLASS="quote">best response ever
Thanks y0!
</TD></TR></TABLE>You sorta have to be a weirdo to own/want one of these bikes. Most owners will tell you the same. I wanted another twin......and I didn't want another SV (650 or 1000). I've wanted an RC for the longest time anyway
LOL<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectF4 »</TD></TR><TR><TD CLASS="quote">best response ever
</TD></TR></TABLE>Thanks y0!
WOW, great response guys
To bad I didn't get an RC
I'm 6'4" and I found it too be real small for me, otherwise I loved the bike...so much so, that I brought another type of 1000cc twin...a 2000 TL1000R.
This thing you guys are a saying about the twins seeming to fall into corners easier then inline's that are even much lighter is true. The twin motor is so compact, the weight is moved real low and forward. Also there is less of a gyro effect from the motor from the lighter crank and slower revs.
Thanx for the advise anyway. I would have loved to get an RC, but I ride alot. Last year I put on 13000km in 6 months
the only problem i have had with mine is a small coolant leak. fairly common i believe. they replaced a couple of clamps and bypass hose. other then that its ok. i love the bike. just wish i had more time to ride
Yah, that was me. The bike is awesome, but man does the seat ever get hot in traffic
It's a pig too, but it really doesn't feel like it when on the move.
Twins just aren't your thing... its all good, they aren't really my thing either, but i can see why people would want them
</TD></TR></TABLE>Twins just aren't your thing... its all good, they aren't really my thing either, but i can see why people would want them
