B16a2 Pistons in a B18c1 with a 20thou head skim
my B18c4 went boom last weekend, I bought a new engine and the head was bowed 15thou across 2&3 so it's been skimmed 20thou to take care of that.
However I'm contemplating fitting some b16a2 0.25 oversized pistons to bump the compression a bit (well to about 12.4:1 with the skim Twisted Evil )
Taking into account the BC3+ cams I'm running, not as much lift as Jun3's or SK2 Stg2's would I encounter valve piston interface moments?
I know people have dropped EK9 pistons into B18c motors with big lift cams like Toda B's, Jun3's etc
Any help would be great
i called skunk2 and according to skunk2 i couldnt run their stage 3's cams in my b18c+ctr's+b16 head.....said not enough piston to valve clearance....so i got the stage 2's instead.....but would also like to know the answer to this question
you will be safe. ive done a few motors using this same set up and we used sk2s3
with no problems. just make sure you degree the cam in properly!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-NYCE »</TD></TR><TR><TD CLASS="quote">you will be safe. ive done a few motors using this same set up and we used sk2s3
with no problems. just make sure you degree the cam in properly! </TD></TR></TABLE>
Do you mean that reply to me, I sure hope so
I spoke to Steve @ Omni Power about my engien and he suggested the B16a2 pistons to give more clearance over the stock (JDM Spec) B18c4 pistons
according to skunk2 its impossible...
94EG2B18
Dec 15, 2011 09:31 PM
GSR_hatch936
Apr 13, 2010 01:14 PM
