what kind of wheels and slicks should i get to fit over my itr 11" brakes
almost everyone i know have lenso's but i only see them in 13's and i'm preatty sure they would fit over my 11" brakes. does lonso's make a bigger wheel?
what kind of wheels should i get that fit over my brakes and what size slicks should i get
so i need the longer wheel studs or spacers to run slicks
you need 15" wheels to clear, and you dont need ext lug nuts if the rim dont need it, if you want to use a spacer its becase you have a fat slick so its dependant on you so it dont rub and the bigger the spacer then you would require ext studs, on a 15" wheel a 22x8x15 is a good size slick esp for all motor, you can go 23 also.
Try looking at the fastbrakes website...
I believe the team dynamics wheels clear their big brake kit.
