Want to Use my Tien Coilovers on My EG...what options do I have?
I have heard that you can machine the metal on the rear lca bushing to make it fit. Could I order new bushings from energy for an ek and put them in my eg lca's. Any ideas would be appriciated.
So I'm guessing your coilovers are from an EK? I doubt that ES bushings for an EK will fit into EG lca's. They're completely different. Not sure though. Why don't you dremel the strut fork support to make it fit? Would that work?
You just shave your factory bushing a little bit to make it fit. You might check first thought because some manufacturers make one set for both applications and include a small bushing to use with an EK.
