ok dumb question but hydro to cable?possible?
Old Apr 13, 2005 | 10:45 PM
turboJDMeg6's Avatar
Default ok dumb question but hydro to cable?possible?
i know most ppl go from cable to hydro and they make kits for it from hasport n etc.
im asking this cause in my 91 civic hb i have a usdm b16a which of course is cable
but my friend wants to buy it and put it into his del sol but he does not have enough money for a hydro tranny.
soooo we are wondering if u can convert it to cable and how hard is it and what do u need to do? ne info would be cool and appreciated! thanks
Old Apr 13, 2005 | 10:51 PM
Luserkid's Avatar
Default Re: ok dumb question but hydro to cable?possible? (91b16ef9)
Yes, they have kits. Is it worth it? **** NO! I hate Cable tranny, its no where close to Hydro. I dont think its worth the time and money to convert but thats me.
Old Apr 13, 2005 | 11:26 PM
Default Re: ok dumb question but hydro to cable?possible? (Luserkid)
me i like cable and he does too but he wants hydro and he cant afford no 600-700$ tranny right now, and he has had no car for lets say about 2months or so. haha, so he was wondering and even i was wondering if its hard to do..thanks for ur input but neone else got there thoughts or if they have done it? thanks
Old Apr 14, 2005 | 08:28 AM
91integraLSVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Yes, they have kits. Is it worth it? **** NO! I hate Cable tranny, its no where close to Hydro. I dont think its worth the time and money to convert but thats me. </TD></TR></TABLE>
whats so diffrent with cable and hydro? i personally like cable better. less parts leads to less break downs. ex failing clutch master cylinder, bleeding clutch lines, leaking slave cylinder etc. dont have to worry about that **** with cable
Old Apr 14, 2005 | 08:42 AM
DJ_SaNdOz's Avatar
Default Re: ok dumb question but hydro to cable?possible? (91integraLSVTEC)
I like cable tranny's as well. I doubt itwill be cost or time effective for this situation though.
Old Apr 14, 2005 | 08:53 AM
dohcdelsol93's Avatar
Default Re: ok dumb question but hydro to cable?possible? (DJ_SaNdOz)
A cable to hydro conversion is only like $200 bucks, i have one from from advid racing componets (hasport also makes one but it's more expensive). I used a 91ls cable tranny in my 93 del sol for quite a while, the clutch felt a bit stiff but it worked fine. You loose the use of the front tranny dampner which puts more stess on the other mounts and causes a bit more motor sway when shifting under heavy load. If your interested in purchasing on used (for about 3 months) i'll sell it cheap. just im me
Old Apr 14, 2005 | 08:54 AM
a1320honda's Avatar
http://www.hasport.com/Product...1.htm
read down a bit, it says they make the conversion from cable to hydro
Old Apr 14, 2005 | 09:39 AM
Default Re: ok dumb question but hydro to cable?possible? (a1320honda)
the 92-93 cable b-series trannies are the same internally as the 94+ hydro trannies. the 90-91 are different
Old Apr 14, 2005 | 11:11 AM
Default Re: ok dumb question but hydro to cable?possible? (dohcdelsol93)
i see thanks for all ur guys input! thanks for the helps! maybe i can finally get my motor sold to him and he can get his car running again. lol
Old Apr 14, 2005 | 12:23 PM
ekb16's Avatar
the converion isnt that bad to do..ive done it myself...b16 cable tranny in a 98 civic.
Old Apr 14, 2005 | 01:47 PM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 &raquo;</TD></TR><TR><TD CLASS="quote">A cable to hydro conversion is only like $200 bucks, i have one from from advid racing componets (hasport also makes one but it's more expensive). I used a 91ls cable tranny in my 93 del sol for quite a while, the clutch felt a bit stiff but it worked fine. You loose the use of the front tranny dampner which puts more stess on the other mounts and causes a bit more motor sway when shifting under heavy load. If your interested in purchasing on used (for about 3 months) i'll sell it cheap. just im me</TD></TR></TABLE>
hasport conversion are $425
Old Apr 14, 2005 | 04:18 PM
a1320honda's Avatar
Default Re: ok dumb question but hydro to cable?possible? (komat)
so could you use the same thing on the "D" series, i know that zc and si trannys are cheap as hell.
Old Apr 14, 2005 | 07:50 PM
nice, thanks for the pics! on a scale of 1-10 how would u rate it as 10 hardest? 5-7? thanks
Old Apr 14, 2005 | 08:11 PM
ekb16's Avatar
lets see, first u gotta drill a hole on the cable lever which doesnt take that long if u knoe wut ur doing...the mounts goes rite into place...the conversion itself is pretty easy...i would say 3-4 around there.
Old Apr 14, 2005 | 09:03 PM
DaMyth's Avatar
how hard would it be to but a b18a with a cable tranny into a 92 civic hatch
Old Apr 14, 2005 | 09:24 PM
ekb16's Avatar
the picture above is my b16 tranny in my 98 civic...it should be the same...basically all u have to do is turn the slave cylinder right side up and drill a hole on the lever on the tranny and put the little square thingy they gave u wit the kit u got and it should all fall into place..pretty easy.
Old Apr 14, 2005 | 09:37 PM
G U E C O's Avatar
any benefit from switching? might i ask y you switched?
Old Apr 14, 2005 | 09:46 PM
Neighborhood Superstar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">
hasport conversion are $425</TD></TR></TABLE>
negative. they used to be $275 back when i got mine, but now theyre $199.
Old Apr 15, 2005 | 05:17 AM
Default Re: ok dumb question but hydro to cable?possible? (=Gameover=)
it's 425 for the entire engine mount and conversion kit. But who needs that when you already have oem mounts
Old Apr 15, 2005 | 08:57 PM
ekb16's Avatar
if u do a cable conversion on r hydro car then u would need a new mount for the passenger side..i used the cable tranny bcuzz i got 2 b16a cable tranny free from my cousin..he just has 1 lyin around so he gave them to me..
Old Apr 15, 2005 | 09:10 PM
CrashAndBurn's Avatar
Have him buy my b16a2
You can do it but it's a pain in the butt. My friend had a ton of problems putting in a b16a in his 94 civic. You also will have to update wiring on the motor to ODBI. Just something to think about
Old Apr 16, 2005 | 03:58 PM
civic94B18B1's Avatar
If you hace a cable tranny and the del sol is hydro all you have to do is get a slave cylinder and set it up under the clutch lever, run a hydro line from the master cylinder to that and your in business
Old Apr 18, 2005 | 12:09 PM
Default Re: ok dumb question but hydro to cable?possible? (civic94B18B1)
more or less that's how it works, don't for get that you have to put some sort of ball joint in that clutch engagement lever so it will pivot properly and the top tranny mount will have to be modified if you dont buy the conversion kit.
Old Apr 18, 2005 | 12:26 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (DaMyth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaMyth &raquo;</TD></TR><TR><TD CLASS="quote">how hard would it be to but a b18a with a cable tranny into a 92 civic hatch</TD></TR></TABLE>
Not hard at all. I've been running a B18A1 with an S1 cable tranny in my EH2 for over two years now.
$199 is way too much...all you get is two brackets and a tie rod end ball joint. I've considered making a kit and selling it myself, but for a much lower price...pretty much just cost of materials [around $40]. You won't get the bling bling HA Sport mount though.
Old Apr 18, 2005 | 12:51 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91integraLSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">
whats so diffrent with cable and hydro? i personally like cable better. less parts leads to less break downs. ex failing clutch master cylinder, bleeding clutch lines, leaking slave cylinder etc. dont have to worry about that **** with cable </TD></TR></TABLE>
He's still gonna have to worry about that. If you turn a hydrolic car into a cable, anyone will still have to worry about those problems.
