Main bearing troubles, please help!
Old Apr 13, 2005 | 08:33 PM
nfn15037's Avatar
Default Main bearing troubles, please help!
OK, I have a JDM ITR block (p72 casting) and the main caps it came with. I tried putting in a good GSR crank with ACLs, but it would bind up, so I took the block to get it align bored. Got it back, put the bearings back in and still no dice. Tried another known good crank, no dice. I am using ACL bearings and a USDM GSR crank, the proper sizes for the crank/block combo is all greens, and the mains plastigauge out perfectly, they just wont spin freely. I have tried a set of OEM greens and no go either with either crank. There is nothing under the bearings, everything is so clean and perfect and it just won't turn. I am at a loss here, someone please help!! I am wondering if JDM blocks use different sizing than USDM blocks.....
Old Apr 14, 2005 | 12:27 AM
SlowReaction's Avatar
Default Re: Main bearing troubles, please help! (nfn15037)
What order are you putting the main caps on? Did you lube it all up before you dropped the crank in and torqued the main caps on?
Old Apr 14, 2005 | 07:46 AM
nfn15037's Avatar
Default Re: Main bearing troubles, please help! (SlowReaction)
I am following the Helms to a 'T'. I have done this about 6 times before with zero problems, but this one is the only JDM block I have done. I was under the impression that they were all the same P72 casting. I even had this one align bored...*sigh*
Old Apr 14, 2005 | 04:16 PM
nfn15037's Avatar
Any ideas? I am going to check with a much more experienced engine builder tomorrow. Everything Plastigauges out fine, it just wont turn....
Old Apr 14, 2005 | 04:22 PM
mmuller's Avatar
Mad Scientist
check roundness and measure mains, measure journals then do the math to see if the bearings your using are correct.
torque 1 main at a time to see if there is a specific one thats causing problems.
just 02
Pandahatch
28
Feb 27, 2006 08:08 PM
Pandahatch
Feb 26, 2006 10:08 AM
poorman's type-r
Jan 25, 2006 04:45 PM
kingteghelm
May 2, 2005 07:38 AM
jweller
Apr 1, 2005 07:02 AM
