96 Honda Accord EX Timing Belt Change
Old Apr 13, 2005 | 08:26 PM
Neldawg's Avatar
Default 96 Honda Accord EX Timing Belt Change
Question for all you accord owners.
I'm planning on changing my timing belt and I already bought a timing belt, balance belt and water pump. What else do I need to complete the job? Someone told me I need some seals other belts?
Anyone has a list of parts that are required for a complete job?
Greatly appreciate your input
Thanks
Old Apr 14, 2005 | 04:29 AM
JimBlake's Avatar
Default Re: 96 Honda Accord EX Timing Belt Change (Neldawg)
Suggestions but they're not exactly REQUIRED...
Tensioner pulleys? Some people automatically replace them, some inspect them carefully while it's easy to see them.
There's oil seals on the balancer shafts, I think there was a recall for some years like yours. Have a dealer check (by VIN) whether yours was done. If not, I think the parts are cheap & you're already doing all the labor to get at those seals.
Since you have to drain coolant, maybe get a new thermostat? Since you have to remove the external drive belts (alternator, etc...), maybe get new ones?
Old Apr 14, 2005 | 08:09 PM
Neldawg's Avatar
Default Re: 96 Honda Accord EX Timing Belt Change (JimBlake)
cool thanks for the info
yea ....i was thinking about the alternator belt and power steering belt as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Suggestions but they're not exactly REQUIRED...
Old Apr 14, 2005 | 09:08 PM
solo2slocivic's Avatar
Cam, crank, and balacer seals(balancer seal retainer!). All drive belts. Water pump and fresh coolant. Valve cover gasket.
You should not need tensioner bearings we might replace 1set in 75 belt jobs and that one is generally on a car getting its 3rd belt or making a noticable amount of noise.
aznromeo4u
Feb 18, 2015 07:51 PM
sirr6
Dec 29, 2013 05:38 PM
Woofers
Feb 12, 2009 05:45 PM
lonestar
Aug 28, 2005 12:07 PM
solid
Feb 3, 2004 10:47 AM
