anyone know what happens if a resistor wire disconnects on a fuel injector?
Got a h22a with a really nasty resister box and found that a wire was disconnected. What would happen or should have happened?
Depends on which wire it is. If it's the main power supply wire to the resistor box then none of the injectors would work at all. If it were a power supply wire to an injector or signal wire to an injector, then only that injector would not work.
Tippyman
14
Mar 27, 2006 08:55 PM
