Jeff @ Import Builder's H22a.....Real or Fake???
Old Apr 13, 2005 | 06:30 PM
mgags7's Avatar
Default Jeff @ Import Builder's H22a.....Real or Fake???
Came across this dyno chart the other day.....basically it is:
H23 VTEC
Type-S Pistons
SMSP Header
2.5 Crush Bent Exhaust
3 Angle Valve Job (Portflow)
IB Modified Stock H22a Intake Manifold
IB "Super Duper" Intake
234 Whp and 178 ft-lbs
Firstly, the dyno rpm numbers are weird for when he points out 7700 rpm peak hp, the bottom says 10.2.....
I have never seen many numbers like this with h22s with built bottom and top ends with good cams....nevermind with just type s pistons and his modded IM.....
I don't question that the SMSP is holding up its end of the hp though....
anyone with some thoughts or maybe knows what the deal is??
if its true im getting one of those IMs and intakes
Old Apr 13, 2005 | 06:36 PM
jnet's Avatar
that looks like a b-series. even with cams the h22 won't make power that high, much less will the h-series trannies even shift at that rpm.
Old Apr 13, 2005 | 06:49 PM
happylude's Avatar
h22 tranny will shift that high. up the rpm. some dynos have em shifting at 8k.
Old Apr 13, 2005 | 07:17 PM
Panda-san's Avatar
Default Re: (happylude)
Is anybody here using that Super Duper intake? I went to their site and the intake section is down.
Old Apr 13, 2005 | 07:23 PM
JDogg's Avatar
Default Re: (Panda-san)
how bout the gayest tq curve evar.... but yea
those numbers on the bottom are TIME in seconds, NOT rpms
thats also the gayest dyno chart ever, time instead of rpm throws the shape of the curves off alot
Old Apr 13, 2005 | 07:26 PM
VTECRaZeR's Avatar
I shift at 8K all day long if I want to...
But I wouldn't just do it with regular Honda tranny oil...
But yea H22 trannies can handle that high or higher RPMs you just need to know how to shift right because you are playing with some crazy screw ups with a miss shift in that high of RPM range
Old Apr 13, 2005 | 08:34 PM
sharkcohen's Avatar
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">those numbers on the bottom are TIME in seconds, NOT rpms</TD></TR></TABLE>
That is correct, we had a discussion about this dyno a couple of years ago on po. In reference to the title, what does this dyno have to do with an H22a?
Old Apr 13, 2005 | 08:59 PM
Eddiebx's Avatar
Default Re: (jnet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnet &raquo;</TD></TR><TR><TD CLASS="quote">that looks like a b-series. even with cams the h22 won't make power that high, much less will the h-series trannies even shift at that rpm.</TD></TR></TABLE>
you can make power that high simply with some cams, and you can shift at 8500 all day long if you wanted, given your tranny aint in bad shape.
Old Apr 13, 2005 | 09:07 PM
vinuneuro's Avatar
Default Re: (Eddiebx)
its using stock cams.
Old Apr 13, 2005 | 10:14 PM
PrecisionH23a's Avatar
Default Re: (vinuneuro)
heres my latest dyno with stock everything
Old Apr 13, 2005 | 10:17 PM
BolivianFuego's Avatar
Default Re: (PrecisionH23a)
Go to sleep Loser. And figure out later whats wrong with your Clearences on your NA motors.
Old Apr 13, 2005 | 10:24 PM
Default Re: (BolivianFuego)
Tracking my posts are we? hehe
Old Apr 13, 2005 | 10:29 PM
NA forum is where im mostly at since i dont own a prelude anymore for sometime.
Old Apr 13, 2005 | 10:34 PM
Then get out of my forum andrew the bitch
Old Apr 14, 2005 | 02:51 AM
mgags7's Avatar
haha.....sorry about the title.....but its basically an h22a....
its .1 liter bigger.....
im thinking the tq curve looks like *** just because of the scaling of the tq axis.....its such a small range of numbers, so each small change is really amplified.....
so i guess anthony thinks its fake....
Old Apr 14, 2005 | 03:01 AM
JDogg's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
....</TD></TR></TABLE>
it has a 20ft/lb spike for probably about 500 rpms...wtf is that ****
Old Apr 14, 2005 | 06:22 AM
crdcz03's Avatar
Fortune Cookie Member
Default Re: (JDogg)
damn he's making 40ish more whp than i am, and all he has over mine is the good header and a 3 angle valve job.
but then again, mine isnt fully tuned yet so maybe theres more in mine
Old Apr 14, 2005 | 07:02 AM
sharkcohen's Avatar
Default Re: (crdcz03)
It's an old dyno, and it's a shitty dyno. So it made 230 whp, so what. It has absolutely no torque below 5100 rpm. It's a dog.
Old Apr 14, 2005 | 07:51 AM
SMSP's Avatar
Default Re: (sharkcohen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">It's an old dyno, and it's a shitty dyno. So it made 230 whp, so what. It has absolutely no torque below 5100 rpm. It's a dog.</TD></TR></TABLE>
According to Jeff's notes, it was already at 153 lb-ft at 2700 and from the graph it looks like his arrow should be going to the 2.1 second mark versus the .5 mark. The time scale is confusing but at least we know what the hp and torque are at 5250 rpms.
Here's a graph of Corey's old engine (h2) and his new engine (H1). The H1 engine has Type S pistons, Jun cams, an Euro Accord IM, no p/s, no balance shafts and a very mildly ported head. This dyno seems to have a tendency to read a tad low for the average run of the mill dyno jet.
Old Apr 14, 2005 | 09:15 AM
Eddiebx's Avatar
hey PRESICION can you email me at eddie@urbanimport.com you PMs suck a fatty and i wanna ask you something,
Old Apr 14, 2005 | 10:06 AM
mgags7's Avatar
yeah, like smsp said, its got low tq....
i just wanted to figure out if the numbers are really true....because that is the cheapest 230whp i have ever seen.....and 180 lbs of tq is awesome.....
Old Apr 14, 2005 | 11:22 AM
sharkcohen's Avatar
Default Re: (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">According to Jeff's notes, it was already at 153 lb-ft at 2700 </TD></TR></TABLE>
Yah, that's my bad, I keep thinking the numbers on the right are the torque scale.
Old Apr 14, 2005 | 02:18 PM
T-King's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">heres my latest dyno with stock everything
That is the funniest thing i have ever seen in my life. HAHAHAHAHAHAHAHAHAHAHA
Old Apr 14, 2005 | 02:38 PM
2point2's Avatar
uh... 5252?
must be JDM.
Old Apr 14, 2005 | 02:50 PM
edulerp97's Avatar
Nice Dyno chart Precisionh23a...LOL
