transmission oil change
Old Apr 13, 2005 | 05:57 PM
xelf's Avatar
Default transmission oil change
stoopid question.
if I am changing the oil in my transmission to the syncromesh stuff. will I need to bleed the cluth lines or do I just pop the bolt drain and then refill?
thanks
chris
Old Apr 13, 2005 | 06:01 PM
AndyD's Avatar
Default Re: transmission oil change (xelf)
Unscrew the drain bolt, screw it back in. Ubscrew filler bolt, filler, screw back in.
I bought a plastic tube to facilitate in the refill. It was VERY easy that way.
Old Apr 13, 2005 | 06:03 PM
951dc5's Avatar
just pop the bottom bolts out and drain it and refill it. Bleeding and stuff is not necessary unless you your clutch fluid is dirty..
Old Apr 13, 2005 | 06:14 PM
xelf's Avatar
Default Re: transmission oil change (Prelude951)
Awesome.
thats all I thought was involved. wanted to make sure. before I did it and find out that I need to do something else!
Old Apr 13, 2005 | 08:37 PM
rjr162's Avatar
for an even easier time find one of those "bottle pump" things. I'll have to snap a shot of the one we have. black pump like something you'd use for a garden sprayer bottle... stick it down into the tranny fluid bottle, and have a hose just long enough to get into the tranny filler hole. Pump until fluid comes out of tranny, you're done.
Old Apr 14, 2005 | 06:02 AM
flyrod's Avatar
Default Re: transmission oil change (rjr162)
When I change it, I drain from the bottom and fill from the vent on the top with a gear oil bottle (the ones with the pointed tip). Piece of cake.
Old Apr 14, 2005 | 06:40 AM
Daemione's Avatar
Default Re: transmission oil change (flyrod)
The hydraulic system for the clutch is completely separate from the transmission fluid . . . no need to touch it for a tranny fluid swap.
Just make sure the car is level when you're draining/refilling it - no jacking up just the front end (or using ramps).
Old Apr 14, 2005 | 06:44 AM
577HondaPrelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">When I change it, I drain from the bottom and fill from the vent on the top with a gear oil bottle (the ones with the pointed tip). Piece of cake.</TD></TR></TABLE>
I use the vent also to fill but with a little funnel
Kyles ej1
Sep 23, 2004 04:41 PM
VChaMarkC
Aug 12, 2004 05:35 AM
98GeeYes-Are
Mar 21, 2003 11:28 AM
Ignitecivic
Apr 3, 2002 01:13 PM
cecknight
Oct 24, 2001 01:54 PM
