CD powers on but no sound
Old Apr 13, 2005 | 05:47 PM
92LudeSI's Avatar
Default CD powers on but no sound
One night everything was fine, now thismorning my cdplayer powers on and i can hear it through the speakers, then it plays but no sound, also the climate control doesnt work. It lights up but when you push the button the light for that area doesnt light up and the blower wont work. Any ideas?
Old Apr 14, 2005 | 08:22 AM
92LudeSI's Avatar
Default Re: CD powers on but no sound (92LudeSI)
Up
Old Apr 14, 2005 | 08:43 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LudeSI &raquo;</TD></TR><TR><TD CLASS="quote">One night everything was fine, now thismorning my cdplayer powers on and i can hear it through the speakers, then it plays but no sound, also the climate control doesnt work. It lights up but when you push the button the light for that area doesnt light up and the blower wont work. Any ideas?</TD></TR></TABLE> Pull the Hu and check for pinched wires, [on HU and any harness, climate control, that is back there] then check the fuses.
Also check for short in speakers or speaker wires 94
Old Apr 14, 2005 | 10:20 AM
92LudeSI's Avatar
I pulled the HU out and all seems fine, i cant imagine any wires would be bad cuz all the speakers dont work. and now the climate control works too. ahhhh ill have to pull it all out and see what the hell is going on. hopefully i dont have to pull the dash out again.
Old Apr 14, 2005 | 12:01 PM
92LudeSI's Avatar
Now it all works I dont know
Old Apr 14, 2005 | 03:44 PM
fcm's Avatar
fcm
Old Fart
Default Re: (92LudeSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LudeSI &raquo;</TD></TR><TR><TD CLASS="quote">Now it all works I dont know</TD></TR></TABLE> Maybe a bad fuse, [not blown just defective] or a bad fuse mount in one of the fuseboxs, it only takes one one shorted out speaker or speaker wire to shut down the amp in the HU, why the climate control didn't work at the same time as the HU I'm also not sure, the HU has a connstant power, [fused at the engine bay fusebox] an acc., [fused at the incar fusebox] and controlled by the ign. switchs acc. circuit, and the climate control is powered by an ign. circuit, [fused at the incar fusebox] and controlled by the ign. switchs ign. circuit, the only thing I can think of that they have in common is grounds, and where they are located, I would check all the plugs around, [above] the HU and into and around the incar fusebox 94
Old Apr 14, 2005 | 04:48 PM
92LudeSI's Avatar
Well I think I fixed it. Turns out there was a pinched wire in the door on the drivers side that was exposted a bit and it must have been grounding out. They reason the climate control didnt work was because it is on the same plug as the front drivers side speakers and if i grounded out the speaker then the climate control wouldnt work. Kinda funny but all seems to be good now.
triple beam
11
Jun 13, 2014 08:31 AM
Midori Green
Oct 27, 2008 07:24 PM
Aarron_M
Feb 26, 2007 09:49 AM
tdgcgpgsr
Jun 13, 2005 06:54 AM
ForcedAccord
Dec 16, 2001 04:55 PM
