can i use a OBD1 OR OBD11 ECU ON B16A1?
Old Jan 29, 2002 | 05:06 PM
civicguy's Avatar
Default can i use a OBD1 OR OBD11 ECU ON B16A1?
i dont want to use the two o2 sensor on the b16a1
anyway to only use one
Old Jan 29, 2002 | 05:56 PM
Jared's Avatar
Default Re: can i use a OBD1 OR OBD11 ECU ON B16A1? (civicguy)
you can have the PR3 chipped to use only one, or you could change distributors and use a wiring harness adapter to run an OBD1 ECU.
Old Jan 29, 2002 | 06:00 PM
Redline130's Avatar
You can get your ecu reprogrammed, there are a few people on this board who provide such service. You could also get a non-obd to obd1 wiring conversion harness. IMO, just get your ecu re-chipped and enjoy the added benefits.
cyber13
Old Jan 29, 2002 | 06:02 PM
Mugen Dom's Avatar
Default Re: can i use a OBD1 OR OBD11 ECU ON B16A1? (cyber13)
get a pw0 it has only one o2 sensor and they make programs for it also not as many though if u decide to get one however make sure it is a manuel car that it came from cause alot of them were automatics or u can run one o2 and put bith wires on it like alot of people do running the obd1 or 2 will not help u in anyway at all
00CivicGirl
Nov 30, 2007 05:36 PM
Ra GS-R
Aug 1, 2007 01:56 PM
CrpX Rotary
Apr 7, 2005 02:16 PM
superls92
Feb 16, 2004 07:38 PM
B16CRXT
Jan 24, 2004 07:16 PM
